60Amp Breaker For Welder... - Electrical - DIY Chatroom Home Improvement Forum
Old 10-25-2011, 11:00 AM   #1
Rewards Points: 83
60Amp breaker for welder...
last year I worked with a retired electrician to run wire, a plug, and install a 20A breaker so that I can run a 220v table saw in my garage. My house was built in 1996 and it has 100A service.
This winter I'd like to borrow my father in laws welder, which requires 220V 60A service. Although the plug is the same as the one for my table saw, the breaker in my houses main panel isn't large enough.
Can I simply replace the 20A breaker with a 60A breaker?
longshanks is offline   Reply With Quote
Old 10-25-2011, 11:22 AM   #2
Rewards Points: 758
NO! You can't just replace the breaker.
I'm assuming it's wired with 12 gauge wire. That is limited to a 20 amp circuit.
How is this wired? Right to the main panel or do you have a subpanel in the garage.
AandPDan is online now   Reply With Quote
Old 10-25-2011, 11:39 AM   #3
Rewards Points: 83
Hi Dan.
I think it is wired with either 10 or 12 ga. wire, I will have to check. There is no sub panel in the garage, I am working off the house's main panel. However, I also have a detached shop that has 60 amp service. Right now the only electrical draw on that panel is a couple of light bulbs. The panel has available space, but is it possible to install a 60A breaker into that panel?
Old 10-25-2011, 11:51 AM   #4
Rewards Points: 758
Hi,
Even at 10 gauge, its normally rated at 30 amps.
I know the welder won't always take 60 amps so that may be an option. It is cutting it pretty close though.
#6 copper is rated at 55 amps, but can be protected at 60. Check with your AHJ.
Old 10-25-2011, 12:05 PM   #5
Rewards Points: 83
I appreciate your input Dan.
I assume what you are saying is that it may be possible to run a 220v 60A circuit off my 60A panel in the detached shop. If so, I think what I'll do is call up somebody qualified to come and look at it. Electricity scares the bejeezus out of me and it would ruin my day if I burned my house down...
cheers
Old 10-25-2011, 12:11 PM   #6
Rewards Points: 758
Yeah, I think that's the best option.
You'd be pushing things pretty good with that welder as it is now.
Good luck!
Old 10-25-2011, 12:54 PM   #7
liscenced electrician
Rewards Points: 538
Are you sure the welder takes 60A?? It may have an output of 60A and an input of 20A
jimmy21 is offline   Reply With Quote
Old 10-25-2011, 01:05 PM   #8
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,214
I was thinking the same thing, 60 amp input welder is a huge machine. Especially since you say it has a 20 amp, 240 volt plug
Coastal South Carolina
Old 10-25-2011, 01:12 PM   #9
Rewards Points: 758
Wow, I missed that completely.
Mustn't have been awake.
Old 10-25-2011, 03:22 PM   #10
Rewards Points: 83
I haven't laid eyes on the thing, but my father in law said it needs a 60A breaker, and it runs on 220V. It's a Lincoln wire-feed flux welder. As I recall, he's been wrong once or twice before
Old 10-25-2011, 03:27 PM   #11
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,956
He is probably wrong. Saying it needs a 60A breaker is VERY misleading.
What is the attachment plug? That will give you your answer as to what circuit it needs.
Old 10-25-2011, 03:33 PM   #12
I=E/R
a7ecorsair's Avatar
If its a wire feed there is a good chance that only needs 20 amps. You said the plug is the same as your table saw and assuming it has factory installed line cord, that would point to a compatible connection.
My Lincoln stick welder has a rated output of 225 amps and only requires a 50 circuit.
a7ecorsair is offline   Reply With Quote
Old 10-25-2011, 04:20 PM   #13
Rewards Points: 83
i think you guys are right about this. He said it's a factory installed plug with two horizontals and a ground. Thanks again for your help.
Old 10-25-2011, 04:25 PM   #14
That is a 6-15P, which is a 15A, 240v plug.
Old 10-25-2011, 04:46 PM   #15
Rewards Points: 29
Most 220 mig welders come with a 50 Amp plug, unless you are going very high end, My Millermatic 180 has a 50 amp plug but max power consumption is listed at 21.7 amps. Output is listed as 180amps
It is my understanding that you cannot put wiring on a 50 outlet that will not support 50amps So I ran #6 to the garage.
You will have to look at the welder to see. Some of the big 220 units do use more that 50 amps but those are pretty expensive and more industrial.
rjgogo is offline   Reply With Quote
AFCI Breaker Keeps Tripping Muinchja Electrical 30 08-25-2011 04:54 PM
Wiring Size Calculations for New Service CorinthWest Electrical 7 12-07-2010 11:36 AM
I can "double" the wires to each breaker in my breaker panel right? Piedmont Electrical 40 10-01-2008 11:18 AM
20 Amp Breaker tripping with GFCI panhandlion Electrical 7 12-12-2007 08:59 PM
Outdoor breaker panel questions lhoney2 Electrical 12 07-19-2007 05:44 PM
