60a Main Fuse Blown - Electrical - DIY Chatroom Home Improvement Forum
Old 11-25-2008, 07:43 AM   #1
60a main fuse blown
I have just built an extension and now have 2 showers, obviously if I use the two showers this will blow the 60a fuse, is their any way (other than uprating the cable and the fuse) that I can protect the main fuse from blowing, ie:60a circuit breaker, if I did fit this would the fuse blow first or would the circuit breaker trip?
beggsy is offline   Reply With Quote
Old 11-25-2008, 07:54 AM   #2
Registered User
Termite's Avatar
If your 60amp main fuse is blowing, a 60amp main breaker will perform the exact same way. My assumption is that your home has a 60amp service, and we're not talking about a 60amp individual circuit. Strange that the main is blowing...Normally the individual branch circuit's overcurrent device will blow/trip before the main does. The only way for the main to blow/trip is for a number of branch circuits to draw a combined total in excess of 60amps, none of them exceeding their own amperage limits.
If we're talking about the main, a service upgrade (perhaps 100, 125 or 200 amps) is very possibly in order.
Old 11-25-2008, 10:21 AM   #3
Rewards Points: 160
Time to upgrade your service. Seriously!
Old 11-25-2008, 11:12 AM   #4
You must cut down on your usage big time, or have a service upgrade. You will need a calculation done if you want to anyways.
The breaker will just trip.
rgsgww is offline   Reply With Quote
Old 11-25-2008, 11:14 AM   #5
DIYer
What do showers have to do with it? We really need more information here.
When was your house built?
Gigs is offline   Reply With Quote
Old 11-25-2008, 12:38 PM   #6
Rewards Points: 2,350
I don't think the OP is in the U.S. or Canada. I do believe he/she is in the U.K. Think about it: the OP built an "extension". And they were curious if it would be better to "fit" a new circuit breaker. I'm betting Brit.
Old 11-25-2008, 04:47 PM   #7
Thanks to everyone who replied, it looks like I will have to fit a 60a circuit breaker at least I can reset this myself without having to call someone to refit the fuse.
Old 11-25-2008, 04:49 PM   #8
DIYer
I guess 60 amps goes further over there since everything's 220. I saw some pictures of UK panels and they are tiny compared to a modern US-NEC panel with all the dozens of required dedicated circuits.
Old 11-25-2008, 05:07 PM   #9
Find a russian panel...they are so small.
Blown fuse.........help! Meg017 Electrical 17 11-10-2008 08:19 AM
Fuse Boxes For Showers Petrena Electrical 3 09-13-2008 01:36 AM
Blown fuse in Control Panel of Carrier Heater jacksup HVAC 3 02-26-2008 05:02 PM
main lug vs main breaker for sub panel diyll Electrical 1 01-17-2008 08:18 PM
Red & Black wire from light = blown fuse leedslad Electrical 3 08-28-2006 06:54 PM
