600W Dimmer, Limits Are What's Connected To The Switch? - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 06-03-2009, 10:28 AM   #16
Rewards Points: 93
Originally Posted by ScottR View Post
Good deal about the 600W.
Even if the 1000W falls within UL limits on temp., it's still hazardous (or at least inconvenient) to have a scalding hot wall plate. Though I guess I'm preaching to the choir on that. If you can split up the load on the 1000W dimmer, that might be your best option, but obviously could be a major PITA.
I put a thermometer on it today unfortunately it's a mouth thermometer and only goes to 109 degrees F and it was all of that. Two things I'll do change the bulbs to 50 watt PAR 20's and I was thinking exactly that dividing the circuit up....looked at it and it won't be a big deal
Thanks for all your help
johnpma is offline   Reply With Quote
Old 06-03-2009, 12:39 PM   #17
DIY'r
ScottR's Avatar
I use Philips Halogena bulbs in all my cans. They're halogen which (IMO) looks better than incandescent, and use 40W for a 65W lighting equivalent. I buy 'em at HD, but I'm guessing they're pretty widely available.
http://www.lighting.philips.com/us_e...flood_spot.php
I know you said you have 75W bulbs now, so they might not be bright enough for you. They're also more expensive than incand., but at least you get some energy savings (you'd be 35W * 8 = 240W lower on your dimmer load).
ScottR is offline   Reply With Quote
Old 06-03-2009, 12:56 PM   #18
Rewards Points: 93
I guess I have to figure out the trim rings we will use. Looks like certain bulbs fit certain trim rings as there is a chart of specific bulbs and trim rings that came with the lights
Can you put 3 dimmers together in a 3 gang box?? I divided the circuit....much better But now I've created a situation where I would have to have 3 dimmers together. Actually looking at it it makes more sense as well to divide the room into two circuits with the IC cans in the ceiling.
Old 06-03-2009, 02:07 PM   #19
DIY'r
ScottR's Avatar
Indeed.. So long as you follow that you'll be OK. The page I linked to you only has 2 different sizes of bulb, but I'm pretty sure there were 3-4 sizes available @ HD.
You can if the mfr. allows it (just like when you derated the 1000W dimmer to 800W, you'd probably have to derate all 3). Also you need to make sure you don't over-fill the box. Depends upon how many wires you have going into the box and how big the dimmers are. If you haven't installed it already, using an extra-deep box couldn't hurt -- the more air space around the dimmers the better.
4 way switch confusion Richo Electrical 10 04-09-2009 07:11 AM
Dimmer Switch Vandiyan Electrical 21 12-15-2008 07:23 PM
Bathroom electronic dimmer gets reset by exhaust fan switch? BinaryJay Electrical 3 07-16-2008 10:57 PM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 01:19 AM
When Bulb blows, Dimmer Switch Blows mAv19 Electrical 2 05-26-2006 03:52 PM
