60 Yr Old House Wirring. - Electrical - DIY Chatroom Home Improvement Forum
Old 12-24-2012, 02:43 PM   #1
60 yr old house wirring.
Ok my living room lights switches. One switch provides a black hot wire to the second switch. the original switches are very old design. One switch used 3 out of 4 poles the second switch was a newer switch using only 2 poles.
The first switch looks like an old toggle switch when the switch is off one side makes contact at the top and the other side makes contact at the bottom.
I tried replacing this switch with a 3 way switch but to no avail.Hot black from 2nd switch to top of this switch with black return from bottom of this switch out.
this is how the original switch was hooked up.The 2 pole switch works fine, but I can not decipher why the second 3 way switch will not send power to the ceiling lights. I have asked electricians and no one seems to have any answers as to how to correct this situation.
Bill1948 is offline   Reply With Quote
Old 12-24-2012, 05:21 PM   #2
DIY staff
Rewards Points: 7,174
Have you used a tester to see what is going on?
Old 12-24-2012, 05:39 PM   #3
Rewards Points: 6,652
See Strange 3-way wiring See if the picture in Post #8 fits your problem.
My house's previous owner - DIY horror stories Leah Frances General DIY Discussions 153 01-21-2016 07:18 PM
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 08:20 AM
Attaching wood fence to house TheCowGod Building & Construction 5 04-13-2012 03:57 PM
Attach ledger to vinyl sided house JamyTheBuilder Building & Construction 3 03-14-2012 02:54 PM
I have Central Heating & Air, but house won't cool down..HELP!! exiledone1 HVAC 13 07-10-2009 10:09 PM
