#1 |
60 amp subpanel install
I plan on putting a subpanel in an attached garage. Not for anything in particular, just a few power tools and a small compressor. The biggest thing is probably my summer/winter hook up that i am moving out there. I expect to put a 60 amp sub in with three 20 slots, one for the heater and two for everything else. I think this might be over kill, but maybe in the future i might have a wood shop! I have heard 6 gauge is sufficient but four gauge is better. Since i don't have much running do you think 6 is ok? Thank you for any input!!
#2 |
Mad Scientist
How long is the run from your main panel to the new subpanel? If it's not very far, #6 is fine, if you're using individual THHN wires in conduit. I think if you're using #6 NM cable, you'll have to bump down to a 50 amp breaker, or go up to #4 wire. I'm not certain on that though.
#3 |
Electrical Contractor
Don't stop with a small panel.
Pick up a 6 or 8 circuit panel, just in case!
Yes I am a Pirate, 200 years too late. "Jimmy Buffett" |
#4 |
it's probably 30-40 feet of wire all running inside. do you mean 50 amp for the feeder?
#5 |
Just call me Andrew
Where are you located? Is this garage attached or detached?
Andrew |
#6 |
Warrington, pa, yes this is an attached garage.
#7 |
If you put a 50 amp subpanel in, you can use #8 THHN. Otherwise, you'll have to go with #6 THHN 194°F which is rated for 75A.
#8 | |
Licensed Pro
60 amp subpanel installQuote:
"Life is hard. Life is harder when you're stupid." John Wayne |
#9 |
Is it code compliant to use a panel rated higher (100A) than the protective device (60A breaker) in the house, or wherever it's located?
#10 |
Mad Scientist
Yep, sure is. The panel only needs to be rated at least as high as the circuit breaker feeding it. The main breaker in the sub-panel, if it has one, is then used only as a disconnect.
#11 |
THANKS FOR ALL YOUR INPUT!!!Let you all know how it turns out!!
#12 |
hey make sure to doublechek the ground, i grounded my box to the main box and I cannot get the 'ground' light to light up on the accessories box
#13 |
Yeah, I was planning on settting a new ground rod into the subpanel anyway, so hopefully i'll be alright.
#14 |
60 amp subpanel install |
#15 |
Licensed electrician
There is absolutely no reason to install this on an attached structure. This requirement is for DETACHED structures.
Answers based on the National Electrical Code. Local amendments may apply. Check with your local building officials. |
| Display Modes | |
| Have questions about adding a 60amp subpanel | humberguy | Electrical | 6 | 05-13-2010 08:57 AM |
| Anyone install a tin/copper style ceiling? | flashme18 | Remodeling | 7 | 07-19-2009 08:56 AM |
| Another subpanel question:) | primal65 | Electrical | 15 | 06-22-2008 10:43 AM |
| Reverse Polarity at the Subpanel | adm060306 | Electrical | 14 | 07-09-2007 01:58 PM |
| Subpanel over Water | JPsAlias | Electrical | 13 | 06-05-2007 11:16 PM |
