-   -   60 amp sub panel (http://www.diychatroom.com/f18/60-amp-sub-panel-14947/)
MsE 12-31-2007 10:31 AM
60 amp sub panel
Hi,
I am installing a sub panel off the main. I was advised by the electrician to buy 6/3 and 4/3 wire. the sub panel has a 2 pole 40 amp breaker and a single pole 20 amp breaker. I am connecting my double wall oven to this sub panel and running my appliances off the 20amp. i am assuming he is going to connect the wall oven to the 40 amp using the 4/3 wire and the 6/3 wire will be run from 2 pole 60amp breaker on the main panel to the sub. Am i right?
Bondo 12-31-2007 10:38 AM
Ayuh,.......
Seeing that 4 gage is Bigger than 6 gage,.....
I believe you have it Backwards........
MsE 12-31-2007 10:43 AM
60 Amp
so 4/3 from the main to the 60 amp and the 6/3 wire for the double oven to the 2 pole 40amp?
Bondo 12-31-2007 10:48 AM
Ayuh,.......
Bigger Wire carries a Bigger Current.......
The 4 gage will carry Both the Oven current,+ the appliances.......
The 6 gage will only be carrying the Oven current.....
MsE 12-31-2007 10:51 AM
thank you so much! I have been very worried about doing this right.
