60 Or 70 Amps To Small Sub Panel - Electrical - DIY Chatroom Home Improvement Forum
Old 11-22-2010, 12:21 PM   #1
60 or 70 amps to small sub panel
please advise proper conduit size and correct gauge of wire
that I should be using, the plan is to come out of the existing
homes all in one meter box, it has extra C/B spaces,
I want to put is a 60 amp or 70 amp 2 pole circuit breaker to
then feed approximately 50 foot, to the Garage, where I will
put in a small sub panel. can I use 3/4 " EMT for this run, or
do I need to jump up to 1 " also, I was hoping that I could use
# 6 gauge THHN stranded wire, a White, Black, Red, & Green.
So, will have to pull 4 wires, please advise Code.
The Sub Panel is main lug only, so it will not have a main c/b.
Thanks PIGEONS
PIGEONS is offline   Reply With Quote
Old 11-22-2010, 12:36 PM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,974
You DO need a main breaker or some from of disconnect for a panel in a detached structure.
Old 11-22-2010, 12:43 PM   #3
main c/b
I don't need a Main in the sub panel, I think it has
something to do with distance, we are only 50 foot
from the main House meter box.
The sub panel will be fed by a 2 pole 60 or 70 anp
220 v this will be like a main, will kill all power if needed.
This Breaker will be in the main houses meter box.
Thanks PIGEONS
Old 11-22-2010, 12:53 PM   #4
I=E/R
a7ecorsair's Avatar
Speedy, Isn't there something in the code about 6 or fewer disconnects? Would that apply to this situation?
a7ecorsair is offline   Reply With Quote
Old 11-22-2010, 12:56 PM   #5
It is doubtful that a 60 or 70 amp sub-panel is going to have a six space (or less) panel.
Old 11-22-2010, 12:57 PM   #6
we are only 50 foot
Thanks PIGEONS
You welcome.
"You THINK", yet you are WRONG.
Would you like the code article and section to support my statements?
Old 11-22-2010, 08:46 PM   #7
60 / 70 amp to sub panel
Alright, you state that I also will need a Main cb in the sub panel.
That would of course be a good thing, basically ending up with
two mains, one at the existing house meter box, and then another in the Sub Panel. the Sub panel is rated : for : Main Lugs Only.
yes, it is a full 12 circuit, or more if you use those thin 1/2 size c/bs,
which I have no intension of using, now, back to this Main circuit breaker being required in this new Sub Panel, I have been advised it is
not needed because the distance to the existing house meter Box is
fairly close at 50 foot, if it is code than I will follow the rules,
Would that mean that I back feed a two pole 60 or 70 c/b and call it the Main for the Sub Panel, I can do that, and just not use the Lugs.
So, please RE-ADVISE, because, I see many sub panels, M L O
installed, with NO main c/b. ? ? thanks PIGEONS
Old 11-22-2010, 08:49 PM   #8
Sub Panel 60 / 70 in garage
The Garage is attached, is part of the house. PIGEONS
Old 11-22-2010, 08:53 PM   #9
sub panel 60 / 70 amp
This Sub Panel is in the Garage ( or will be ) the Garage is attached
to the House, the conduit run is only going to be approx. 50 foot.
PIGEONS
Old 11-23-2010, 07:26 AM   #10
to the House
PIGEONS
Well this would have been good to know from the start.
When we hear "I am running conduit 50' out to the garage to a sub-panel" we unfortunately assume it is detached.
NO, for a panel in an ATTACHED garage you DO NOT need a main breaker or disconnect.
Old 11-23-2010, 11:06 AM   #11
Rewards Points: 204
Does that matter? Inspectors cannot inspect for the future. Regardless of the number of spare panel spaces, if no more than 6 handles are installed at the time of the inspection it would be compliant.
sub panel ground and neutral daddyrabbit Electrical 3 01-29-2010 06:49 AM
How to determine amps coming to main panel? RyanP Electrical 16 08-26-2009 03:23 PM
100A Fuse Panel Replacement Charlie1101 Electrical 4 07-25-2009 02:22 PM
Melted Service Entrance Wire in Panel theatretch85 Electrical 13 08-22-2008 10:37 AM
Multiple Sub Panel Installation Handyman2007 Electrical 26 12-31-2007 05:47 PM
