6"x6" Metal Square Box? - Electrical - DIY Chatroom Home Improvement Forum
Old 07-13-2013, 02:04 PM   #1
Rewards Points: 1,654
6"x6" metal square box?
I have seen somewhere before that Raco or someone else makes a 2" deep 6"x6" square metal box with knock out holes on the sides and back.
I searched and couldn't find it. I even looked up grainger.com.
Anyone know where or is it my imagination?
Also if they make one with this size, does it have it's own mud rings and cover plates? Or you have to convert it to a 4"x4" opening for a regular size cover?
miamicuse is offline   Reply With Quote
Old 07-13-2013, 02:11 PM   #2
NEVER MIND. Found it.
http://www.garvinindustries.com/elec...ockouts/6150-s
1.5" deep though.
Old 07-13-2013, 03:15 PM   #3
MarginallyQualified
Rewards Points: 2,464
what are you trying to do?
Old 07-13-2013, 04:10 PM   #4
Sparky
Rewards Points: 510
http://www.garvinindustries.com/elec...junction-boxes
Those are available in 1.5", 2.5", and 3.5" deep.
They use specific plaster rings, here.
Techy is offline   Reply With Quote
Old 07-14-2013, 07:31 PM   #5
Electrician
Rewards Points: 802
What is the point of that box, I have never seen anything like it. I am sure a 4 11/16x4 11/16 with a plaster ring will be more then enough room.
darren is offline   Reply With Quote
Why can't you connect Ground/Neutral bus bars on a sub secutanudu Electrical 42 11-07-2012 01:33 PM
How to best tell what is square and what is not? miamicuse Building & Construction 12 07-14-2012 08:44 PM
Paint for Rust-Prone Exterior Metal Railings (Oil-Based Metal vs Epoxy vs Urethane) Einhorn Painting 9 06-19-2011 08:41 PM
Replacing metal box caused issues rivers001 Electrical 28 03-07-2011 12:21 AM
Poor Attic Ventilation Mechanically Challenged Roofing/Siding 15 10-23-2008 09:05 PM
