6 Wires Under One Nut - Pass Inspection? - Electrical - DIY Chatroom Home Improvement Forum
Old 08-24-2010, 08:54 AM   #1
Rewards Points: 81
6 wires under one nut - Pass inspection?
I am concerned that I will have six 12 guage wires under one wire nut in order to hook up all the components in my 3 gang switch box. I calcuated that I am Ok with fill requirements.
I am rewiring a bathroom for the following components:
1. 2 outlets
2. 1 exhaust fan
3. 1 main light over sink
4. Nightlight inside exhaust fan
5. Center light in exhaust fan.
I was planning on bringing my power into the 3 gange switch box which has the following switches:
1. Motion sensor for the nightlight
2. Regualar switch for light over sink
3. double switch for exhaust fan and center light in exhaust fan.
I will have 12/2 going up for the fan and another 12/3 wire up to run the center light and night light. I have 12/2 wire runing to the outlets and another 12/2 running to the light over the sink. All wires run from the switch box to the component.
What is the best way to wire this? can I jumper two wire nuts together to reduce the amount of wires under each nut. I don't feel comfortable having that many wires under one nut.
hartkem is offline   Reply With Quote
Old 08-24-2010, 09:50 AM   #2
Rewards Points: 1,418
Can't judge what is best but I have often jumpered (pigtailed) together wire nuts so no one wire nut has too many wires in it. More than five wires and there is a good chance one of the wires will end up "in the middle" and not be bitten into by the wire nut spring. Then it has a chance of slipping out.
Pigtails and wire nuts count zero points for box fill (U.S. NEC). But together with something big like a motion sensor (same two points of box fill), your box may be too crowded for comfort. You might want to consider a quad gang box instead of a double switch in a triple box.
How easily can you run power to the receptacles first and daisy chain up to the switch box? Then you do not need a power continuation from the switch box to the receptacles.
Old 08-24-2010, 01:45 PM   #3
Rewards Points: 81
The walls are studs only now because I am remodeling. I could easily run power to receptical first. I have to use GFI in the bathroom so this would cause the lights to go out too. Is this OK to do? I think I may put the exhaust fan light and the fan on the same switch so I can reduce the amount of wires in the box.
Old 08-24-2010, 04:33 PM   #4
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
as long as you use a wirenut that is listed to accept 6 #12 wires, it will pass inspection. An Ideal blue 454 is one such connector.
Old 08-24-2010, 05:31 PM   #5
zpm
yeah, right
There's also the push in connectors. Ideal and a couple of other companies make them.
http://www.idealindustries.com/prodD...v=0&l1=push-in
Honey, does this tool belt make me look FAT?
zpm is offline   Reply With Quote
Old 08-24-2010, 05:38 PM   #6
As convenience goes ^ reliability may go \/.
http://www.google.com/search?client=...UTF-8&oe=UTF-8
Old 08-24-2010, 09:00 PM   #7
" Euro " electrician
frenchelectrican's Avatar
Either Grey or large bleu one will work just fine on this appaction and I have no issue but let me pass a tip on this one please pretwist it then put the Grey or Big Bleu wirenut on it will be much easier to do that way.
When you get done with it then you have to fold it carefull I know it will be stiff but it can be done if you take couple extra seconds.
Merci.
Marc
Old 08-25-2010, 01:12 PM   #8
DIY'er
jamiedolan's Avatar
Rewards Points: 1,024
I've used the grey scotchlocks and they have worked well. What I have found to work the best is this:
Strip the wire far longer than necessary, 2-3 inch, this makes it easy to grab and get a good grip on with a big pliers.
Line up all the insulation, grab wire with hand firmly by insulation.
Use the largest pliers you have to twist, I use a 11" for this.
Once twisted, use a good side cutters to cut the exposed wire to the proper length, I cut at a little angle.
Look at the end of the wires, and count that there are the correct number, make sure the insulation did not slide out of position and expose bare wire where it will be below the wire nut.
Twist on wire nut.
If this sounds way too hard, use a Wago.
Jamie
jamiedolan is offline   Reply With Quote
Old 08-26-2010, 12:48 PM   #9
Totally screwed together
You could also split them up - 3 under one nut and 3 under another - with a jumper between. This gives you two nuts with 4 wires under each, much more managable.
xxPaulCPxx is offline   Reply With Quote
Question regarding bonding wires - Ontario Code? jim.thornton Electrical 6 08-17-2010 09:23 AM
Removing wall with wires in it jboswald Electrical 11 11-29-2009 03:55 PM
Need help with the lingo, inspection didn't quite pass moneymgmt Electrical 12 10-29-2009 06:17 PM
Three hot wires coming into a receptacle? Jeff DIY Electrical 10 10-07-2009 02:35 PM
Old house, new light fixture, too many wires Persephonee Electrical 3 01-15-2007 09:58 AM
