6 Wire Box Fan Motor - Electrical - DIY Chatroom Home Improvement Forum
Old 03-01-2012, 05:01 PM   #1
6 wire box fan motor
how do I wire a 6 wire fan motor with these connections:
blue, red, black, yellow, green, white
blue to red= 13 ohms
blue to black = 40 ohms
blue to yellow = 5 ohms
yellow to black = 35 ohms
yellow to red = 8 ohms
red to black = 27 ohms
white to green = 250 ohms
thank you
dave webster is offline   Reply With Quote
Old 03-01-2012, 05:16 PM   #2
joed's Avatar
Rewards Points: 12,458
Sounds like a four speed fan.
Green=ground
White=neutral
blue,red black, yellow are the four speeds. Connect any one them and the white to the power and it should run.
Old 03-01-2012, 05:29 PM   #3
Rewards Points: 282
Green=ground
White=neutral
i disagree....
give us a part number..or the wiring diagram is probably on the plate anyway.
yellow can be the hot and black the HI on lots of motor wiring, also 120v, 220v, 480v, etc..
no way to have any clue what is what from those wire colors or the wire-wire resistance.
jcrack_corn is offline   Reply With Quote
Old 03-01-2012, 05:47 PM   #4
6 wire fan motor
motor is a 3 speed, reversing, 120 volt
no motor wire is grounded to frame
the switch is labeled L1, 1, 2, 3 on the bottom
and S1, S2, A, B on the top
there is a 2 wire run capacitor 3mfd
Thank You
Old 03-01-2012, 08:55 PM   #5
joed's Avatar
OK so now there is a switch. Is it connected to anything?
Is there any name or model number on the motor?
Old 03-01-2012, 11:33 PM   #6
6 wire motor
it is a powr kraft box fan, no model, no tags, no wire connections, no power cord. A neighbor offered to paint the fan for a friend, he took it apart and asked if I could put it back together, it has me stumpted. The switch is a 16 position General Electric, no model number. I tried to find any information on the Montgomery Ward Powr Kraft fan but no luck. Thank you
How wire an HP 1.0 Motor Dayton ? Conquistador Electrical 5 01-27-2012 07:34 PM
wire condensor motor pallet Electrical 0 11-29-2011 01:18 PM
wire leads on Reliance Motor abnormalnorman Electrical 13 06-30-2010 09:49 AM
New fan motor going out? DavidI HVAC 5 06-23-2010 10:38 AM
Neutral Wire? 4x15mph Electrical 8 11-24-2008 01:00 PM
