#6 Aluminum Cable - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 03-11-2009, 12:22 PM   #16
Its not a pull out, but it works just fine.
rgsgww is offline   Reply With Quote
Old 03-11-2009, 12:58 PM   #17
Rewards Points: 2,350
Not at 277 it won't. To the OP, what is it exactly you are trying to do? Aluminum wiring won't cause your timer to "blow".
Old 03-11-2009, 01:22 PM   #18
Question
trying to connect #6 aluminum cable to a 40 amp mechanical time switch.
hooked it up to new timer and timer won't work.
Emailed to Intermatic Manufacturing who says you cannot connect aluminum cable to this timer. (40 amp double pull single throw 208-277 V AC 60 Hz)
Trying to hook up aluminum to something else and then take copper from there to the timer.
penticton is offline   Reply With Quote
Old 03-11-2009, 01:25 PM   #19
I get that part, what I'm driving at is, what voltage are you working at? The timer you specify will only work on 208-277 V.
Old 03-11-2009, 01:48 PM   #20
working at 240 Volts
Old 03-11-2009, 02:43 PM   #21
I missed the 208/277 part
It *disconnect I showed* will not work just fine for 277.
Old 03-11-2009, 02:54 PM   #22
Licensed Pro
If the timer is designed to work in the range 208-277V, then it will work just fine at 240V.
As was pointed out, the AL wire will not cause the timer to blow. Make sure you have the correct voltage timer, and make sure you are connecting it properly.
Old 03-11-2009, 03:04 PM   #23
Question
okay , now I am confused.
Can I use the 60 A 240 Vac disconnect box to attach the #6 aluminum cable and then go with 8/3 copper from the disconnect box to the time switch?
Will I be using Penetrox A when I connect the aluminum cable to the disconnect box?
Old 03-11-2009, 04:06 PM   #24
The disconnect is ok if your working with 240v.
You cannot use 8 awg nm on a 50 amp breaker.
About the 6 awg aluminum, is it romex? What is the insulation type?
Nm cable is limited to the 60 deg column.
Old 03-11-2009, 04:28 PM   #25
Yes , the aluminum comes from the main 200 amp panel, it has a 50 amp breaker.
I am not sure if I fried the other timer, I just know that it is not working.
I have another new one now , so would love to do this right.
The aluminum is: Alcan SM 3C 6 AWG ACM Nual NM D 90 XlFE 3000 Ft1 CSA . hope this answers that question.
I could use 6/3 from the connector box to the timer.
would I want to use the penetrox A compound on the aluminum connections in the connector box. ?
thanks
Old 03-11-2009, 05:37 PM   #26
What you need to do is replace the 50 amp breaker with a 40 amp since you derate nm cable to the 60c column, for AL, this is 40 amps.
After doing that, you can use 8 awg copper.
The anti oxidant is a good idea.
Old 03-11-2009, 09:48 PM   #27
Thank you, I think I've got it...
Satellite vs. cable coaxial types? Badfish740 Home Theater 6 02-17-2009 12:00 PM
No Signal From Tv Cable LJMSURG Electrical 17 10-11-2008 09:00 AM
Coaxial Cable Question bahaisamurai Home Theater 9 08-08-2007 03:54 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 01:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 04:35 PM
