Old 06-07-2014, 10:17 AM   #1
Share |
#6 or #8 wire conductors how to tell?
I recently acquired a property and found out there is a big thick romex running on two 60A breakers to a tanked water heater which does not require those wiring. My guess is at one point they had planned on a tankless ran the wires then decided not to.
Problem is I can't see the jacket labels on both ends. The jacket was stripped as soon as entering the junction box and the panel. I wanted to make sure those are #6 conductors and not #8 for the tankless.
I removed a short piece of the conductor and took it to Home Depot, put it against their #6 and #8 and still can't tell. The guy at HD can't tell either.
Looking at the strands, mine has seven thick strands. The conductors at HD has many more strands but each strand is much skinnier. Is there a way to tell for sure without crawling into the attic to look for the wire jacket that's readable? It's under a lot of blown insulation Grrrrr....
miamicuse is online now   Reply With Quote
Old 06-07-2014, 11:17 AM   #2
If it's running to a tank water heater, there should be some exposed cable between the wall and the tank, no?
IslandGuy is online now   Reply With Quote
Old 06-07-2014, 11:44 AM   #3
No. The thick romex ran to a junction box in the utility room, then was spliced to two #10 conductors to run to the tanked heater. That's why it was speculated it was wired for a tankless then something changed.
Old 06-07-2014, 12:15 PM   #4
A "Handy Husband"
rjniles's Avatar
If you are going to use the water heater tank, just change the breaker to a 2 pole 30 amp and forget it.
Coastal South Carolina
Old 06-07-2014, 12:30 PM   #5
Measure the wire diameter and compare to this chart.
http://www.southwire.com/ProductCata...prodcatsheet46
The Following 2 Users Say Thank You to jogr For This Useful Post:
MTN REMODEL LLC (06-07-2014), rjniles (06-07-2014)
Old 06-07-2014, 01:18 PM   #6
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Picture of the wire?
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
The Following User Says Thank You to plummen For This Useful Post:
Know A Little (06-07-2014)
Old 06-07-2014, 01:21 PM   #7
Licensed electrician
Regardless of stranding it is not hard to hold up next to a piece of a known size and compare.
Old 06-07-2014, 01:25 PM   #8
cj133's Avatar
Is it copper or aluminum?
How long is the run?
Don't mean any disrespect by asking this, it's just something that occurred to me that could be a huge issue for some.
Steam heat pictures.
https://picasaweb.google.com/thetube0a3/Boiler?authkey=Gv1sRgCImUxIqv9436MQ#
1933 GE Monitor Top refrigerator restoration video
http://youtu.be/y2LWjT3e7uQ
cj133 is offline   Reply With Quote
Old 06-07-2014, 01:27 PM   #9
Rob
Robpo's Avatar
picture of wire next to a piece of #6 & #8
Robpo is offline   Reply With Quote
Old 06-07-2014, 04:56 PM   #10
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Jogar.... Thanks for the chart.... I printed it for reference.... every once in a while you just can't read the sheath.
But, could you tell me what "2ft/sec wind and sun" is reference to when it says "Ampacity is based on 75 degree wire,25 degree ambiant, 2ft/sec wind and sun.) (Bottom footnote on the chart.)
TIA
Best
MTN REMODEL LLC is online now   Reply With Quote
Old 06-07-2014, 04:59 PM   #11
cj133's Avatar
TIA
Best
It means the wind is blowing 2 feet per second with the wire in the sun @ 25C ambient and the conductor is 75C at that current rating.
Compared to romex which is usually in a confined area and insulted and I wouldn't want to see more than 37C or so conductor temp.
The Following User Says Thank You to cj133 For This Useful Post:
Old 06-07-2014, 09:18 PM   #12
I don't plan to. I wanted to change to a tankless and if the wiring is already there that much better. I just wanted to make sure the conductors are #6 and not #8. Both me and the Home Depot electric guy put it next to a #6 and a #8 and couldn't conclusively tell.
The Following User Says Thank You to miamicuse For This Useful Post:
Old 06-08-2014, 01:41 AM   #13
It's copper. I am not sure the exact length of the actual run. The distance between the panel and the junction box is about 30', if you add in 5' or so on both ends for the drop that will make it 40', however I have no idea if it coils, twists and turns in the attic so at least 40'.
Old 06-08-2014, 03:24 AM   #14
I have a feeling it will sit there for a while
Mocking you every day !
dmxtothemax is offline   Reply With Quote
Old 06-08-2014, 05:47 AM   #15
Well here's the thing, if you're going from tank to tankless, you're probably going to need something better than #8 or #6 for a whole-house tankless to provide instant hot water to the degree that a tanked heater can with only #10s on a 30a breaker.
The Following 4 Users Say Thank You to IslandGuy For This Useful Post:
garlicbreath (06-08-2014), jbfan (06-08-2014), plummen (06-08-2014), stickboy1375 (06-09-2014)
Use red and black wire as 110 in Canada mattm Electrical 10 11-26-2012 07:40 PM
THWN wire; Gray pvc Conduit; and GFCI receptacles Buzzy Electrical 29 09-26-2012 02:41 AM
Connect luminaire stranded wire leads to multiple twisted solid conductors zubor Electrical 2 09-07-2012 08:42 PM
convert 3 wire range junction box to receptacle filby Electrical 0 06-05-2011 01:33 AM
HALP! Master/Remote Dimmer troubles! Confuserated Electrical 9 02-12-2010 03:30 PM
Copyright © 2003-2014 Escalate Media. All Rights Reserved.
