#1 |
6/4 AL for Attached Garage Sub Panel
I have a length of 6/4 Aluminum cable that I'd like to use as a 40 amp feeder to a small sub panel in my attached garage. I can get a picture of the cable later today but one thing I do remember about the cable is that it does not have the ground wrap around all the conductors, its un-insulated and is twisted all by itself.
Question is, can I use this through the wall and run to a sub panel in my garage? I already know everything there is to connecting a subpanel, I am just questioning the use of the aluminum cable I have. Edit: its type SE/SER cable, see the attached picture.... Last edited by theatretch85; 04-27-2009 at 12:49 PM. Reason: Added Picture |
#2 | |
My License Ain't 4 Sale..
6/4 AL for Attached Garage Sub PanelQuote:
#3 |
UAW SKILLED TRADES
Agreed, SER AL (service entrance---round type) may likely be the most common sub-panel feeder for 40 and above amps used by electricians with nm-b being the most commonly used by do it yourselfers up to 60 amps. You cannot go underground with it though. SER sounds like just the ticket for your application.
" One nice thing about the NEC articles ... you have lots of choices" Stubbie |
#4 |
Awesome, got it from a buddy who's store closed down and got some electrical stuff for cheap. Just need a small sub panel for outlets to run some tools, air compressor, possibly a welder down the road (small one). This run will be a short run (probably about 50 feet) and would be easy to change out in the future if needs change. Thanks!
| Display Modes | |
| Old House Rewire | finnimus | Electrical | 15 | 05-13-2011 11:39 PM |
| Next Question, Sub panel in detached garage... | OmegaBunny | Electrical | 5 | 09-16-2008 12:37 AM |
| Replacement Meter Panel | leonard_voet | Electrical | 19 | 04-09-2008 11:27 AM |
| Detached Garage Sub Panel Grounding Q | integlikewhoa | Electrical | 13 | 01-01-2008 07:22 AM |
| Detached Garage Sub Panel | MainePainter | Electrical | 6 | 08-25-2006 10:58 AM |
