6-3 Wire For Spa - Electrical - DIY Chatroom Home Improvement Forum
Old 08-27-2013, 04:26 PM   #1
6-3 wire for spa
Am I allowed to splice indoor 6-3 wire to outdoor 6-3 wire in a junction box. And then run the outdoor wire to the spa disconnect box?
ellbri is offline   Reply With Quote
Old 08-27-2013, 04:45 PM   #2
Oso954's Avatar
Rewards Points: 1,132
No.
But you can splice 4 single conductor THWN #6 to the indoor wire and run it in conduit to the spa disconnect box.
Oso954 is offline   Reply With Quote
Old 08-27-2013, 05:29 PM   #3
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,216
Spa/pool wiring requires an insulated ground the same size as the ungrounded conductors.
Coastal South Carolina
Old 08-27-2013, 07:28 PM   #4
Its 6-3 +1 growing wire in each. Home depot says I can aplicw then together to save money. I door is way cheaper than outdoors. At the end, right before it goes outside I would splice outdoor 6-3 +1.
Old 08-27-2013, 07:46 PM   #5
A "Handy Husband"
rjniles's Avatar
WTF are you talking about? Growing wire??? Don't take your electrical advice from an orange apron.
Old 08-27-2013, 08:38 PM   #6
dmclean701's Avatar
Rewards Points: 152
Wow, do people proof read their own posts? Some of them are almost unintelligible. I think he meant "grounding wire" .
Sent from my iPad using DIY Forum
dmclean701 is offline   Reply With Quote
Old 08-27-2013, 09:03 PM   #7
That's what I get for doing this on my phone. I'll take everything back to home depot and just use outdoor wire for the whole thing.
Old 08-27-2013, 09:22 PM   #8
Electrical Contractor
jbfan's Avatar
Rewards Points: 490
You can't use outdoor wire for the spa.
Old 08-27-2013, 09:26 PM   #9
I'm just using the outdoor 6-3 +1 wire from the fuse box to the spa disconnect which is outside. I'm not hooking up the spa yet. That's a whole other thread on this forum.
Old 08-27-2013, 09:29 PM   #10
jbfan's Avatar
Rewards Points: 490
Is the spa disconnect on the side of the building?
Old 08-27-2013, 09:38 PM   #11
Yes it on the outside of the house. I'm wiring it from the fuse box to the outside of the house
Old 08-27-2013, 09:46 PM   #12
jbfan's Avatar
Rewards Points: 490
If you only go from the panel to the disconnect without going outside, you can use the wire you have.
Old 08-27-2013, 09:50 PM   #13
I am going outside. So I will return the inside wire and use outside wire from fuse box to disconnect box which is located on outside of house
Old 08-28-2013, 12:39 AM   #14
" Euro " electrician
frenchelectrican's Avatar
If you have a disconnect switch right on outside wall of the house the 6-3 NM can be used only if it allowed in your area.
But once it get outside the game do change you can not use the bare ground conductor from disconnect switch to the spa.
There are few parts of NEC code ( if ya in USA ) you have to follow it.
It will be in Art 680 if my bells are ringing right.
And check the spa manufacter instruction for any specfic size conductor or set up so check it ahead of the time to make sure you doing the right thing.
Merci,
Marc
THWN wire; Gray pvc Conduit; and GFCI receptacles Buzzy Electrical 29 09-26-2012 02:41 AM
ceiling fan wicked97 Electrical 4 08-21-2011 08:12 AM
convert 3 wire range junction box to receptacle filby Electrical 0 06-05-2011 01:33 AM
HALP! Master/Remote Dimmer troubles! Confuserated Electrical 9 02-12-2010 03:30 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
