6/3 NM Stranded Or Solid To Run To 50A Subpanel - Electrical - DIY Chatroom Home Improvement Forum
Old 10-30-2008, 02:00 PM   #1
Rewards Points: 1,062
Question
6/3 NM stranded or solid to run to 50A subpanel
this is going from the house into a detached garage. inside the house, i will use 6/3 NM and then have a switch from which it it continues outside to the garage on UF.
however, i noticed lowes has only 6/3 NM in stranded and not solid. is that okay ?
also, is there a switch for that kind of amperage (50A) ?
thx,
- a -
Old 10-30-2008, 02:41 PM   #2
Solid #6 would be impossible to work with.
They make all kinds of switches rated at 60 amps.
220/221 is offline   Reply With Quote
Old 10-30-2008, 03:18 PM   #3
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,992
It doesn't matter. You will not find #6 NM cable in solid.
Speedy Petey is online now   Reply With Quote
Old 10-30-2008, 03:33 PM   #4
makes sense. thanks.
Old 10-31-2008, 10:52 AM   #5
Rewards Points: 246
You don't need a switch. You will have a breaker in your main service panel that will be the switch. A junction box is sufficient. How do you plan to splice the #6 wires or is that why you want a switch?
Old 10-31-2008, 12:14 PM   #6
true to that but i plan to use the switch in lieu of a JB so that i can switch from the back of the house near where it exits and joins the UF cable. if a JB could be hidden behind DW, i would do it then but since any JB MUST BE EXPOSED, i might as well have a switch. it is a "might as well" type of situation.
Alarm Wire, Stranded or Solid? gfchew Electrical 7 04-11-2016 03:04 PM
Adding a subpanel to a sub-panel and other questions CardinalPilot Electrical 14 03-30-2011 02:23 PM
Another subpanel question:) primal65 Electrical 15 06-22-2008 09:43 AM
Reverse Polarity at the Subpanel adm060306 Electrical 14 07-09-2007 12:58 PM
