6/3 Cable - Splice In Ceiling - Electrical - DIY Chatroom Home Improvement Forum
Old 04-19-2012, 09:49 PM   #1
Rewards Points: 187
6/3 cable - splice in ceiling
As far as I know every splice needs to be accessible. Is there a way to splice a 6/3 cable in the ceiling without having it in a box? I want to run the cable to the garage for an electric vehicle charger but the piece I had turned out short. I have an extra piece but the splice would be in the kitchen ceiling.
What I've seen in other countries is something like a cast resin shell/box in which the wires are spliced and then resin is poured in the shell/box to completely fill it.
Do you know of something that can be done in this case which can stay unaccessible in the closed and finished ceiling?
Jaxx is offline   Reply With Quote
Old 04-19-2012, 09:54 PM   #2
Electrical Contractor
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
All splices much be in a junction box and always be accessible. If you don't want that then you must run a new wire the correct length so a junction box is not needed.
With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Old 04-19-2012, 10:24 PM   #3
jbfan's Avatar
Rewards Points: 656
Do you have an attic above the kitchen?
If you have access to the area above the kitchen, then the box is accessible
Old 04-19-2012, 11:06 PM   #4
Run it down the kitchen wall behind a cabinet, cut out the back of the cabinet and put a blank cover on it.
fdiddy is offline   Reply With Quote
Old 04-19-2012, 11:19 PM   #5
Sparky
Rewards Points: 510
or put in a false hvac vent
Techy is offline   Reply With Quote
Old 04-20-2012, 12:12 AM   #6
Rewards Points: 187
No attic. vaulted ceilings.
The cable is not long enough to route it into a wall. Also I would need 2 huge holes in the top plate to get the cable in. (I should have mentioned it is 6/3 UF-B cable, I know, this is unusual for indoors but that's what I have to do the job and 6/3 isn't cheap)
Old 04-20-2012, 03:33 AM   #7
Rewards Points: 1,192
Use all that money you'll save in gasoline to buy the right cable.
bobelectric is offline   Reply With Quote
Old 04-20-2012, 04:39 AM   #8
Ravenworks's Avatar
Concur
Ravenworks is offline   Reply With Quote
Old 04-20-2012, 07:38 AM   #9
joed's Avatar
Rewards Points: 13,766
If you put the splice at the panel would it be accessible? Pull the cable through to the garage and splice it at the panel.
Splice 3wire cable run with nicked insulation ARC&SPARK Electrical 1 11-30-2010 04:31 AM
Re-route dryer electric cable Stu27 Electrical 10 09-06-2010 08:21 PM
10 Cable Junction Box Splice swstx Electrical 8 07-06-2010 09:16 PM
50 Amp Circuit - Splice 6 Gauge Cable to 12-3? jodic Electrical 4 01-23-2010 12:10 PM
cable splice kit instead of juction box? pat72 Electrical 18 07-21-2008 05:12 PM
