5500w Briggs And Stratton Generator. - Electrical - DIY Chatroom Home Improvement Forum
Old 05-04-2009, 06:31 PM   #1
canfixmost
5500w Briggs and Stratton Generator.
I could probably figure this out, but thought this may be qucker.
Problem- only getting 120v out of generator.
Fuses are good.
I cannot find any info online for troubleshooting.
Any Ideas?
Thanks in advance.
Don
RenoDon is offline   Reply With Quote
Old 05-04-2009, 07:43 PM   #2
DIYer
You are going to have to be way more specific.
Gigs is offline   Reply With Quote
Old 05-04-2009, 08:11 PM   #3
canfixmost
Ok, see pic of generator. I took apart the control panel and tested for 220v where the leads come out of the gen befor they get to the circui breaker and could not get 220v only 120v on one leg.
If you ask a question I could be more specific. I just don't know what else to tell you.
Old 05-04-2009, 08:16 PM   #4
canfixmost
Heres the pic I hope
Old 05-04-2009, 09:36 PM   #5
31b
sparky
you should only get 120+/- from each leg
31b is offline   Reply With Quote
Old 05-04-2009, 09:40 PM   #6
31b
sparky
are you saying from L1 and L2 combined you're only getting 120?
Old 05-04-2009, 09:43 PM   #7
canfixmost
Yes thats correct. For example L1 to ground 120v L2 to ground 0v
Old 05-04-2009, 09:44 PM   #8
31b
sparky
what do you get from line to neutral? (on both of them)
Old 05-04-2009, 09:51 PM   #9
canfixmost
same thing
Old 05-04-2009, 10:04 PM   #10
31b
sparky
you get 120V from L1 to neutral and 120V from L2 to neutral? should work fine then. L1 to L2 will give you 240.
Old 05-04-2009, 10:12 PM   #11
canfixmost
Sorry, what I meant was I get 120v on L1 and 0v on L2. Same as testing to ground.
Old 05-04-2009, 10:20 PM   #12
31b
sparky
oh, well there you go, one leg is not putting out power. somewhere there's a lost of broken connection back to the alternator, or open winding.
Old 05-04-2009, 10:32 PM   #13
canfixmost
Thats what I figured, guess I'll just take it apart and start lookong around.
Wires to alternator are good so it must be the winding or something on the other end.
Old 05-04-2009, 11:02 PM   #14
Rewards Points: 150
A while back I was having problems with my coleman powermate 6250, No output at all. I don't know if it would be related but I called the company and they said they were having problems with the diodes and it was an easy fix. They wanted me to bring the generator to a repair shop for the fix, I told them the place was too far, So I said just send me the diodes and I'll do it. And they did. After I replaced the diodes the problem was solved and it's been running for about five years now with no problems.
James Con is offline   Reply With Quote
Old 05-04-2009, 11:13 PM   #15
canfixmost
Are the diodes located on the rear portion of the alternator? I think I saw them. Probably no way to test?
Thanks for your input.
Briggs and Stratton generator part Jeremy Hillary Boob, PhD Electrical 3 01-10-2009 10:36 AM
5+ Year old Briggs & Stratton Won't Start Chris_In_FL Landscaping & Lawn Care 1 08-28-2008 07:41 PM
Briggs and Stratton Murray lawn mower issues golfer2b Landscaping & Lawn Care 3 08-01-2008 09:42 PM
Briggs & Stratton recall Big Bill Safety 2 09-28-2007 04:35 AM
