Is This A 50W Or A 150W Light Bulb? - Electrical - DIY Chatroom Home Improvement Forum
Old 07-23-2012, 01:09 PM   #1
Is this a 50W or a 150W light bulb?
I found this old large light bulb, but can't tell if that dark thing in front of "50W" is a number "1" or some symbol I don't know about.
I want to plug this into a 75W socket, but am afraid it'll melt the socket...
gsur is offline   Reply With Quote
Old 07-23-2012, 01:20 PM   #2
Its hard to tell by picture but compare the "one" in the wattage to the 1 for the 120 volts
austinbblock is offline   Reply With Quote
Old 07-23-2012, 02:18 PM   #3
MarginallyQualified
Rewards Points: 2,464
It sure looks like 150W from here.
do you have an amp meter?
Old 07-23-2012, 02:46 PM   #4
No, but I can get a hold of one. So I can use an amp meter to read the wattage on a bulb? how do I do that?
Old 07-23-2012, 02:49 PM   #5
No company I'm aware of manufactures a G40 globe in a 50w. They are very common in a 150w however so that's likely what you have.
LooseSCruz is offline   Reply With Quote
Old 07-23-2012, 05:20 PM   #6
From the surface area of the globe it's a pretty high wattage. Notice how big a 10W bulb is.
For a 120v, 150W bulb the cold resistance is ~(120^2)/(150x12) = 8 ohms, for 50w it's 24.
Old 07-23-2012, 07:12 PM   #7
dmxtothemax's Avatar
Rewards Points: 5,608
Do you have a digital type multi meter ?
If so, measure the resistance and compare it to any other
150w incandesant light bulb.
they should be simulair.
Judgeing by the size of the glass envelope,
I would guess it is a 150w bulb !
dmxtothemax is offline   Reply With Quote
Old 07-23-2012, 08:29 PM   #8
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Screw it in to a socket turn it on...if its really bright...its 150W.
The Following 5 Users Say Thank You to k_buz For This Useful Post:
bbo (07-23-2012), DangerMouse (07-24-2012), Evstarr (07-24-2012), J. V. (07-24-2012), mpoulton (07-23-2012)
Old 07-23-2012, 10:40 PM   #9
Alright, thank you guys for your help!
I'm pretty sure it's 150W.. Didn't know they were so cheap, so I'll probably just get a lower wattage G40 bulb just in case...
Old 07-24-2012, 12:13 AM   #10
" Euro " electrician
frenchelectrican's Avatar
The other thing you will not see very often anymore is a 150 watts G-40 bulbs anymore that is getting very rare now.
They will be pretty bright when you first turn them on.
Merci.
Marc
Old 07-24-2012, 06:37 AM   #11
the Musigician
DangerMouse's Avatar
I'd just about guarantee that's a 150W bulb. I have one here that looks exactly like it. It's BRIGHT!
DM
Old 07-24-2012, 11:28 AM   #12
Rewards Points: 246
150 watts was pretty standard in the 75/100/150 watt bulbs we all grew up with. You guys can sure complicate stuff. And yes. It says 150 watt right on the bulb.
Light Wiring Question mataguri Electrical 4 11-09-2011 02:15 AM
Light bulb in fan goes off and on ilyaz Electrical 2 07-19-2010 09:00 PM
Light Bulb Burst Mark Harvey Electrical 4 02-20-2010 12:54 PM
Do I need training to change a light bulb? Mechelle Electrical 11 08-13-2008 07:26 AM
Flourecent light bulb question shadango Electrical 7 06-28-2008 08:28 PM
