50A Subpanel, FPE Breaker In Main Keeps Tripping At 38A.. Upgrade To 60A? - Electrical - DIY Chatroom Home Improvement Forum
Old 08-07-2012, 10:22 PM   #1
50A subpanel, FPE breaker in main keeps tripping at 38A.. upgrade to 60A?
I think that the wire is getting too hot... it is run through just under 50' (wire is the same) of 3/4" PVC on the side of the house, exposed to the sun 8+ hours each day. 100+ F most of the summer.
2 8AWG hots, 2 10AWG neutrals and 1 12AWG ground.
Rental so I can't really mess with the FPE main unfortunately but I need to upgrade the wire and breakers ASAP.
I have 60A 2 pole breaker already installed in the main going to an unused 4 ton AC that is out of commission and I can use. I'd like to use that in order to add a new circuit (5A max in addition to the 38A) to the subpanel. So considered the heat + sun on outdoor conduit, what size wire will I need? I assume 6 but don't wanna find out later I need to repurchase 50' of wires.
All loads are continuous 20+ hours/day. 38A is 240v, new 120v will only pull 5A. Do I need to upgrade the neutrals as well?
Sorry for such a needy first post I'm just stressin over this. Thanks in advance for any advice!
yeahman is offline   Reply With Quote
Old 08-08-2012, 07:08 AM   #2
Licensed electrician
Rewards Points: 1,880
Many areas will only allow the owner of their home to perform any wiring in the home. You mentioned a rental so you should talk to the landlord. If you are the owner of the rental you should hire someone for liability reasons.
breaker keeps tripping RMCarner Electrical 29 07-22-2012 09:53 AM
Wiring Size Calculations for New Service CorinthWest Electrical 7 12-07-2010 11:36 AM
Advice on Upgrade Main and Sub and new sub rugby1 Electrical 5 02-09-2009 10:43 PM
Main Breaker is tripping rdmccaw Electrical 18 02-05-2009 10:27 PM
Replace main panel or use subpanel? MasterofNone Electrical 8 02-12-2008 12:24 AM
