50a 4 Prong RV Connection With 3 Wires? - Electrical - DIY Chatroom Home Improvement Forum
Old 10-19-2010, 10:04 AM   #1
50a 4 prong RV connection with 3 wires?
When we built our home (3 years ago) we had the electrician install an outdoor RV receptacle. He ran 3 wires to a four prong receptacle - two hots #8 and an uninsulated #10 ground. He then jumped the ground to neutral on the back of the receptacle with a piece of the same #10 uninsulated. All wire is copper. Is this up to code?
droptop92 is offline   Reply With Quote
Old 10-19-2010, 10:26 AM   #2
In a word..... NO
It should have an insulated neutral run with the circuit, not a "bootleg" job.
If you had the same "electrician" wire your house then you'd better look other places, too.
You might want to buy some additional fire insurance.
alfred e neuman is offline   Reply With Quote
The Following User Says Thank You to alfred e neuman For This Useful Post:
droptop92 (10-19-2010)
Old 10-19-2010, 10:58 AM   #3
I think you answered my follow-up question. Wondered if I could continue using the uninsulated #10 as the neutral and just run a separate ground wire to a new ground rod at the base of the receptacle.
Unfortunately, I have a 40' run through walls and ceiling (behind sheetrock) to 'fix' this mess. Doubly p*ssed off that my 'electrical' inspector didn't pick up on this. Only wish I knew what other hazardous things to look for. Thanks!
Old 10-19-2010, 11:20 AM   #4
Mad Scientist
Yep, to be legal you need an insulated #8 neutral.
And for the record, because this is a common point of confusion, a ground rod does nothing as far as providing a safety ground for a circuit. The ground needs to carry any fault current all the way back to the panel, to allow enough current to flow to trip the breaker.
Ground rods are primarily to give lightning a reasonably safe path to the earth in the event of a strike.
McSteve is offline   Reply With Quote
Old 10-19-2010, 11:30 AM   #5
Hey, thanks for clarifying the ground wire/rod confusion. Looks like I'll be calling the electrician to see how he'll remedy and then the inspector if we can't come to a reasonable fix. Thanks for the guidance!
4 prong 220v recep. to a 3 prong mopowers Electrical 12 05-03-2012 07:39 PM
Unintended kitchen remodel Itsdanf Project Showcase 191 06-14-2010 12:23 PM
Confusing Chandelier Wires Burnsy Electrical 21 02-22-2009 04:29 PM
Unfused connectors MELTED House wires WHAT TO DO??? jamiedolan Electrical 63 02-12-2009 07:01 PM
Running new doorbell wires after ripped old ones out? pcampbell Electrical 3 12-14-2008 12:31 PM
