500mcm Thhn - Electrical - DIY Chatroom Home Improvement Forum
Old 11-07-2012, 03:08 PM   #1
500mcm thhn
What size wire is each strand in 500mcm thhn?
DBOND12345 is offline   Reply With Quote
Old 11-07-2012, 08:20 PM   #2
Idiot Emeritus
Rewards Points: 1,492
Typically, it's 37 strands of approximately #9AWG.
micromind is offline   Reply With Quote
Old 11-08-2012, 06:06 AM   #3
Julius793's Avatar
Who cares? :-)
Electricity will kill you if you give it a chance
Julius793 is offline   Reply With Quote
The Following User Says Thank You to Julius793 For This Useful Post:
Speedy Petey (11-08-2012)
Old 11-08-2012, 06:50 AM   #4
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,878
How the hell did you know that?
Old 11-08-2012, 07:05 AM   #5
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Something similar to that was on my JMan's test.
Old 11-08-2012, 08:23 AM   #6
Licensed electrician
Rewards Points: 1,272
I don't know why you would need to know that for a Jman test, or any other for that matter.
The Following 2 Users Say Thank You to Jim Port For This Useful Post:
Julius793 (11-08-2012), Speedy Petey (11-08-2012)
Old 11-08-2012, 03:28 PM   #7
Julius793's Avatar
Well then how about a 900mcm how many strands? :p
Old 11-08-2012, 05:51 PM   #8
Master Electrician
Rewards Points: 3,768
Southwire's 750 and 1000 has 61 strands.
brric is offline   Reply With Quote
Old 11-08-2012, 08:03 PM   #9
Idiot Emeritus
I based my answer on the NEC. Chapter 9, table 8; Conductor Properties.
It states that 500MCM has 37 strands and each strand is .116" in diameter. It also states that #10 solid is .102", and #8 is .128. So #9 is somewhere in the middle.
The reason questions like this are on tests is not so you know how many strands are in 500MCM, that is just about as useless as it can get. But if you know how to look up obscure facts, then you know how to use the codebook to answer more common questions.
I believe though that the code could be greatly simplified. If it were reduced to about 1/3 of its present volume, I think it's be a lot easier to look stuff up. If you can't find it, you can't follow it.
For example, if you're connecting a motor, you need to look in at least 5 different articles; 110, 240, 250, 310, and 430. There's no reason for this. The provisions of 110 and 240 could easily be in 430.
Sorry for the rant, I've seen way too many problems with the complexity of the code.
Rob
P.S. 900MCM has 61 strands, each one is slightly smaller than #8.
60 AMP circut- Romex or THHN? crankcase Electrical 10 07-20-2011 11:35 PM
3-way switch loop with thhn WillK Electrical 4 05-26-2011 04:51 PM
NM vs THHN Ampacity sirsparksalot Electrical 14 05-07-2011 06:22 PM
Wiring a Spa and THHN question. skleinsmith Electrical 29 04-02-2010 12:41 PM
Number of Strands in THHN jamiedolan Electrical 9 01-03-2009 03:50 PM
