50 Volts, + Or -, From Neutral To Ground? - Electrical - DIY Chatroom Home Improvement Forum
Old 05-13-2012, 06:48 PM   #1
50 volts, + or -, from neutral to ground?
Is it normal to get a voltage on a single pole light switch from neutral to the ground?
higgins is offline   Reply With Quote
Old 05-13-2012, 06:55 PM   #2
Rewards Points: 1,548
No.
Probable causes:
1. Phantom voltage, not unusual to see this using a digi6tal meter. Does it drop to zero if you connect a small incandescent light acrosst he two places you touched the meter probes to?
2. A loose connection somewhere in the neutral path or tin the ground path back to the panel.
Again, what two places are you touching the meter probes to?
Old 05-13-2012, 07:16 PM   #3
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,274
You should not have a neutral connected to a switch.
Coastal South Carolina
rjniles is offline   Reply With Quote
Old 05-13-2012, 08:09 PM   #4
Electrical Contractor
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
Switch leg?
With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
The Following User Says Thank You to rrolleston For This Useful Post:
gregzoll (05-13-2012)
Old 05-13-2012, 08:24 PM   #5
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Switch loop with a dimmer or a open neutral.
Old 05-13-2012, 09:46 PM   #6
joed's Avatar
Rewards Points: 13,740
It is sometimes normal to get voltage from the white wire to the ground at a switch. Whites at switches are not always neutral.
2 wire outlets: connect neutral to ground? border collie Electrical 19 04-12-2013 12:29 PM
50 Amps for a garage help IcyShadowz Electrical 48 05-31-2012 10:58 PM
Real Basic Electrical question re: neutral wire hellothere123 Electrical 22 07-21-2009 06:07 PM
Electrical connections TazinCR Electrical 11 01-07-2009 07:10 PM
Nuetral from feeder cable to main panel question? TW Lucas Electrical 14 05-08-2008 11:33 AM
