50 Amps For A Garage Help - Electrical - Page 4 - DIY Chatroom Home Improvement Forum
Old 03-29-2012, 08:18 AM   #46
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
One thing I haven't seen mentioned is GFI protection. All recepts in a garage need to be GFI protected by either a GFI device, or GFI breaker.
Old 05-31-2012, 04:44 PM   #47
Apprentice Of all trades
Thanks for adding that part I was kinda planing on doing that anyways just in case wasn't really sure if it is needed or not but planed on it anyways. I still haven't started this project but plan on doing so within the next couple of months ill take pictures as i go along as of right now i still have all the same stuff in place just buying pieces and lots of reading. First im talking to the code enforcer / inspector to see if i can increase the size of my garage. My biggest issues im running into is the fact of where it was built to begin with im going to have to move the garage 5ft towards the opposite side of my yard because it is too close to my property line to do any new construction ie making it 6ft bigger on one side. My garage is a 20x14 and i want to increase it to a 20x20. i find it kinda silly being that the garage is already there and the guy could cut me some slack its not like im trying to make the building 60x60 im doing a 6ft increase so hes looking at it to see what can be done.
IcyShadowz is offline   Reply With Quote
Old 05-31-2012, 06:16 PM   #48
Ravenworks's Avatar
Apply for a zoning variance,in most cases it will be granted for an existing structure.
U.S.M.C. "80-84" E.O.D. 1369
Ravenworks is offline   Reply With Quote
Old 05-31-2012, 10:58 PM   #49
Although that would be really cool if possible but he keeps telling me that its because of fire code buildings being to close together which would make since but due to the fact like your saying the building is already there. The only issue i see here is a zoning variance is like 100 bucks and to move my building 5 ft south which might even be less depending on the property line wouldn't really cost much but im trying to work with the guy and hes seems like he might be cool about it so im waiting on his decision. I do appriciate the fact that you brought that up i didnt even think about doing that so that is a good option thanks.
Weatherproofing garage help Perfik Building & Construction 2 10-17-2012 03:30 PM
Garage floor Tomperro Building & Construction 3 07-17-2011 11:37 PM
Pouring Concrete Slab in a small rickety garage. RORO Building & Construction 0 10-19-2010 03:56 PM
Generator as sole power source NGuy Electrical 29 12-20-2008 12:29 AM
Max amps allowed - electrician advice needed Des Electrical 27 06-05-2008 10:31 PM
