50 Amp RV Service - Electrical - DIY Chatroom Home Improvement Forum
Old 01-20-2011, 06:26 AM   #1
50 amp RV service
I have to move my RV plug out another 100'. It currently runs underground 100' from the main panel using 4 - #6 THHN wires in plastic.
My question is can I add another 100' to this run? If so should I now use #4 or will #6 be good? Or will I have to start all over from the main in order to run the entire 200'?
hd82 is offline   Reply With Quote
Old 01-20-2011, 08:55 AM   #2
Rewards Points: 1,494
I don't have the calculations but I say it is safe to do this.
Figure out the wire size for redoing the entire run.
Use an equal amount bigger than that for the new extension, keeping the existing section as-is. For example if you would need one size larger (here, #4) wire for the entire run, leave the #6 wire in place and use one more size larger (here, #2) wire for the extension.
(For those eavesdropping, if the extension were longer, yet a larger size would be needed to have negligible added voltage drop while keeping the existing wires in use.)
Old 01-20-2011, 09:24 AM   #3
Electrical Supplier
Rewards Points: 150
By my calculations he should be able to extend his wire to 200 feet with 6/6/6/6 copper and only be at 4.1% Voltage Drop at full amp load. (you want no more than 5%)
I say extend it with 6/6/6/6 Copper THHN to your new location.
Using #2 would be wasteful and unnecessary for this job.
"Do it right the first time and avoid duplication of effort"
Your AHJ/Inspectors ALWAYS have the final say on ANY electrical code issue.
If in doubt, contact a licensed, experienced, reputable electrician to perform the work.
LyonsElecSupply is offline   Reply With Quote
Old 01-20-2011, 10:10 AM   #4
Electrician
Rewards Points: 790
Is it 3% or 5% in a branch circuit. I know in Canada we are allowed only a 3% drop in a branch circuit and I thought the US was the same.
darren is online now   Reply With Quote
Old 01-21-2011, 03:35 AM   #5
From the info I get on different wire size calculators to run a new line I would need 200' of #4.
http://www.csgnetwork.com/voltagedropcalc.html
http://www.csgnetwork.com/wiresizecalc.html
If I understand the replys here I should use #4 to extend from the original. Or I can run a new 200' with #4.
The price of #4 varies from $1.02 at Lowes to $0.80 at NOTOCO here in New Orleans. If I go with a new 200' run can I use 4-4-6-8 then add a ground rod at the end? #6 neutral is $0.55 and #8 ground is $0.33, I already have the 1/2" ground rod.
Old 01-21-2011, 05:09 AM   #6
Rewards Points: 1,192
Are you drawing even 30 amps continually? Then extend # 6 Thwns.
bobelectric is offline   Reply With Quote
Old 01-21-2011, 06:15 AM   #7
I don't know what the draw is or will be, this is my first RV and I just bought it 3 wks ago. It has a 50amp plug so I ran a 50 amp service.
It has two A/C units and a full size refrig, ceiling fan, convection microwave, electric water heater. I don't have a clue as to how many amps it will pull in the summer time. This is why I want to be sure I get it right, so I ask the gurus of electric to give me advice.
Old 01-21-2011, 06:18 AM   #8
You'll be fine.
Old 01-21-2011, 07:41 AM   #9
Just redid my calculations and, if you can take a 4% voltage drop at the full 50 amps (voltage drop will be under 3% at 40 amps) then you can go with 6 gauge copper all the way. (using 0.4 ohms per 1000' for 6 gauge)
For under 3% voltage drop at 50 amps you can run #4 for the extension leaving the existing #6 in place back to the house. You would not need to upgrade the latter unless you need more than 50 amps at a later date.
The number of volts dropped in any segment of wire equals the amperes flowing times the resistance of that segment and does not depend on the supply voltage. However you must also follow the wire size/type versus amperes rules for example no more than 30 amps for #10 copper Romex cables.
Lennox service valve questions leeh1212 HVAC 12 07-26-2013 08:59 AM
Wiring Size Calculations for New Service CorinthWest Electrical 7 12-07-2010 11:36 AM
Service mast options bsperr Electrical 6 12-09-2009 08:48 AM
Remodel - Moving from 200 amp service to 320 amps stevedar Electrical 20 11-29-2009 08:14 PM
Grounding for two service entrances to same house. jogr Electrical 18 09-24-2008 10:31 AM
