50 Amp Receptacle In Shop - Electrical - DIY Chatroom Home Improvement Forum
Old 11-12-2011, 11:14 AM   #1
50 amp receptacle in shop
I want to install a 50 amp receptacle in my shop. It is in a pole building where the walls and ceiling have been framed in. The receptacle will be flush mount in a box. My question is what is the best way to go about installing it to meet code. For instance what size/type gang box should I use and type of connection to it using the 6/3 type wire. The receptacle is for my welder. Being that it is 220v it does not have to be GFI protected ?
Any help would be appreciated.
stevo1213 is offline   Reply With Quote
Old 11-12-2011, 11:50 AM   #2
Electrical Contractor
kbsparky's Avatar
You only need 6/2 w/ground for a welder.
You can use a standard 2-gang nail-up box for such an installation.
Use a flush mount device:
And a 2-gang plate:
-KB
Old 11-13-2011, 01:50 AM   #3
Thanks KB,
I assume you knock out both center pieces for the wire to enter the box due to the wire size. There would be no GFI protection in this case either correct? Thanks for including the pics.
Old 11-13-2011, 09:13 AM   #4
Spend the extra couple of bucks and put this recpt. in a metal box with a properly sized connector. You wont be disappointed.
roblectric is offline   Reply With Quote
Old 11-13-2011, 07:49 PM   #5
kbsparky's Avatar
Originally Posted by stevo1213 View Post
Thanks KB,
Not necessary to knock out more than one of those entrance holes. I've been able to fit a piece of 6/2 into them without ruining the box. I use the hole closest to the stud, and put a staple in the cable within 8" of the box.
You are not required to have GFCI protection for welder outlets.
-KB
The Following User Says Thank You to kbsparky For This Useful Post:
stevo1213 (11-14-2011)
Old 11-14-2011, 12:59 AM   #6
Thanks KB,
Is there a minimum height that is required for outlets either 110v or 220v which are in a garage/shop?
I have been placing them at 48 inches but may place some lower since some will be under some light switches.
Old 11-14-2011, 11:27 AM   #7
Rewards Points: 502
Only if you are talking a long run or maybe for an industrial welder. My Miller 252 is perfectly fine with 8 gauge and I am pretty sure that is what is in the factory cord. Remember welders have a pretty low duty cycle near peak output. You won't be running near 50 amps (and most welders use quite a bit less) for long periods of time with most welders made.
If you want to use the circuit for a stove or kiln, then I would agree 6 gauge wire would be in order.
forresth is offline   Reply With Quote
Old 11-14-2011, 02:56 PM   #8
Rewards Points: 768
i agree with that, a plastic box will break after few connect-disconnect of the welder. Get a metal box solidly anchored
carmusic is offline   Reply With Quote
Old 11-16-2011, 08:55 AM   #9
So if I used a metal box, then I would need to splice the 6/2 wire with a grey wire nut and ground the box as well? I have found that when you get to that kind of size wire, splicing in a box like that can be difficult.
Replacing receptacle with GFCI wiring problem braden Electrical 8 04-06-2011 08:32 AM
low voltage reading at receptacle 2 ball cane Electrical 5 04-06-2011 12:07 AM
Wiring a receptacle for a lift station hydrogeo99 Electrical 4 08-18-2010 01:04 AM
Receptacle Rating question Ultrarunner2017 Electrical 5 12-18-2008 05:36 PM
Split Receptacle on 3-Way Circuit NPS Electrical 6 11-03-2005 09:28 AM
