50 Amp GFI Reverse Fed Breaker - Electrical - DIY Chatroom Home Improvement Forum
Old 11-02-2011, 11:47 AM   #1
50 amp GFI reverse fed breaker
How do i wire a reverse fed 50 amp gfi breaker( Schneider stab loc 5mA non auto/back/reverse fed breaker), initially it was wired w the reverse fed breaker in the box, which then fed a panel box with two back to back 50 amp breakers which then led to hot tub. IS THIS SAFE as a GFCI/GFI???
jhkitchen is offline   Reply With Quote
Old 11-02-2011, 11:56 AM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 386
You can not back feed a gfci breaker.
jbfan is online now   Reply With Quote
Old 11-02-2011, 12:10 PM   #3
Thank you; does that mean I CANNOT use this breaker as a hot tub GFI; or did the addition of back to back breakers enable it as a GFI even though it was not back fed.
Old 11-02-2011, 12:12 PM   #4
jbfan's Avatar
Rewards Points: 386
I'm not sure what you mean by back to back, but a gfci will only offer protection if it is installed per instructions.
Old 11-02-2011, 01:09 PM   #5
again; thanks for any help. The hot tub was wired w this 50 amp breaker w a red 5mA test, ( it says on it " NON AUTO, this device must be reverse fed" but i dont think it is a "real" gfi; it has red/black and two whites; load and line; but it had two 50 amp breakers ( normal breakers) further down line, which i refer to as back to back and then went to hot tub. Can it be a gfi configured like this, it seems to work fine. but is it a real gfi? how do i find out; without throwing a HOT toaster into tub.THX
Old 11-02-2011, 02:13 PM   #6
jbfan's Avatar
Rewards Points: 386
A pic would answer many questions.
Tags
50 amp gfi??
AFCI Breaker Keeps Tripping Muinchja Electrical 30 08-25-2011 04:54 PM
Wiring Size Calculations for New Service CorinthWest Electrical 7 12-07-2010 11:36 AM
I can "double" the wires to each breaker in my breaker panel right? Piedmont Electrical 40 10-01-2008 11:18 AM
20 Amp Breaker tripping with GFCI panhandlion Electrical 7 12-12-2007 08:59 PM
Outdoor breaker panel questions lhoney2 Electrical 12 07-19-2007 05:44 PM
