50 Amp GFCI Tripping - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 07-16-2009, 02:53 PM   #16
You could run just hot and neutral jumper wires to the line side of the unmounted GFCI, with nothing on the load side. If it trips it almost certainly is bad.
Then add the ground wire and see what happens.
If it works so far add wiring to the load side.
If it still works add the load.
Divide and conquer.
Old 07-16-2009, 02:53 PM   #17
Take a picture of the main panel and the sub panel. Sounds like you have a bad breaker but let's look over everything.
jerryh3 is offline   Reply With Quote
Old 07-16-2009, 02:57 PM   #18
jerryh3, that is the conclusion I came to but thought I'd better check and see if I did something stupid here. I plan on exchanging the GFCI on my way home today. If that doesn't work, I'll certainly take pictured and palsture them up to get experts input.
casnart is offline   Reply With Quote
Old 07-16-2009, 02:59 PM   #19
300zx's Avatar
Post
Thats why i wondered if it was a new gfci and pics help alot good luck you do need a ground bar in the sub panel
300zx is offline   Reply With Quote
Old 07-16-2009, 03:03 PM   #20
Thank you all for your help! I will post tomorrow what happens tonight.
Old 07-16-2009, 05:31 PM   #21
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
From your description of the problem you do not have the feeder to the gfci energized at the main panel. The gfci will not hold without power getting to it. You need the ground hooked up only to get the test button to work and for safety. But you gotta have power at the gfci first.
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
Old 07-16-2009, 07:36 PM   #22
Electrical Contractor
jbfan's Avatar
If this is a spa box from the box store, make sure the gfci is installed in the middle.
I installed one and put the 2 pole gfci on the smae leg, turned on ower and lost the gfci.
jbfan is online now   Reply With Quote
Old 07-16-2009, 09:28 PM   #23
Licensed Pro
If you have power at the spa panel and the breaker trips immediately with no load, then you have a bad breaker.
The ground in the panel has nothing to do with the test button, it should test whether the ground is connected or not.
Old 07-16-2009, 11:50 PM   #24
UAW SKILLED TRADES
Stubbie's Avatar
Yep.. no ground...test will still work...sorry
Thanks for catching that Househelper.... a rather silly over site on my part.
Stubbie
Old 07-17-2009, 07:32 AM   #25
It was a bad GFCI! Got a new one, snapped it in and all is good.
As a side note, Menard's wouldn't take the bad one back because the decals were scratched and it looked "used". So I guess Lowe's and Home Depot get all my business now.............
Old 07-17-2009, 07:40 AM   #26
300zx's Avatar
Post
Glad you have it fixed.Good Job!!
Old 08-17-2011, 05:12 PM   #27
New question, same topic
Hi All, I have the same problem in this thread. I have replaced the breaker and it too worked again... for while. been about a year, maybe less, and the 'new' breaker is now tripping again with nothing on the load side. If I remove the breaker from the panel, it will latch 'on' but as soon as its put back into the panel (and the coiled white neutral attached to neutral bar) it trips. Could this be just 'crap luck' or something else going on to 'burn out' these GFCI breakers? In the 50A outside box (single non-GFCI from house panel to outside box) I have a 20A and a 30A GFCI. The 20A feeds the electronics and the jets, the 30A feeds the heater. at $75 a pop, I dont want to be replacing these things once a year...
Thanks in advanced!
jbreault is offline   Reply With Quote
LCD TV tripping GFCI breakers throughout house penleydr Electrical 34 01-27-2017 06:09 PM
Freezer tripping GFCI davidclements Appliances 58 07-03-2015 06:46 AM
Random GFCI tripping, Data Rack theatretch85 Electrical 5 07-10-2009 09:20 PM
New GFCI Breaker Tripping w/ 3-way Flourescents BigJimmy Electrical 8 12-29-2008 03:29 PM
20 Amp Breaker tripping with GFCI panhandlion Electrical 7 12-12-2007 09:59 PM
