50 AMP Circuit Entry Through Foundation - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 06-05-2008, 07:01 PM   #16
analogmusicman's Avatar
Rewards Points: 560
how come wire strippers are different for stranded and solid wire?
tnx,
analogmusicman is offline   Reply With Quote
Old 06-05-2008, 07:23 PM   #17
Power Gen/RS Engineer
Rewards Points: 566
tnx,
Because stranded is slightly larger than solid for the same AWG size.
Well, now, there's what's right and what's right and never the twain shall meet.
BigJimmy is offline   Reply With Quote
Old 06-05-2008, 07:47 PM   #18
Rewards Points: 560
ok. HD hasn't got wire strippers for #6 stranded OR solid so I'll havta try Lowes or something.
tnx,
Old 06-06-2008, 06:18 AM   #19
Electrical Contractor
jbfan's Avatar
Rewards Points: 380
tnx,
You can save a trip. You will not find one there, either. Just use a knife.
jbfan is online now   Reply With Quote
Old 06-06-2008, 08:34 AM   #20
Rewards Points: 566
Originally Posted by jbfan View Post
Just use a knife.
Or, if you already have a stripping tool, open the jaws and put the cable in the seat of the cutting knives then rotate the jaws while squeezing the handles together slightly.
Old 06-06-2008, 02:26 PM   #21
Rewards Points: 560
well, to be honest I DO use my utility knife when stripping wire. but,I read (probably on this forum) that there's a danger of "nicking" the wire when you do that and all sorts of catastrophes happen then!
tnx,
Old 06-07-2008, 09:15 PM   #22
Licensed Electrician
jrclen's Avatar
Rewards Points: 514
I know many electricians who use a utility knife to strip wires. I prefer a sharp pocket knife. Either one takes some practice and some care. Generally, anything over #10 is work for a blade of some type. Proper technique is important.
John
jrclen is offline   Reply With Quote
Old 06-10-2008, 02:41 PM   #23
Rewards Points: 560
ok,the story goes on: rented HD's biggest hammer drill and a 1 3/8 bit and put a hole through the foundation. a weathertight j box is now attached to the outside foundation wall with 3/4 pvc running through the hole. next, I'll get that big romex up the inside wall and run it through the pvc to the outside, then I'll run all that conduit and pull those expensive wires through. lastly, I'll slap in a 50A breaker and connect everything. will post some pix when it's done. moving kinda slowly at this point. the hangup is getting my panel upgraded.
tnx,
Need a wiring diagram Mooreski Electrical 47 02-01-2015 03:07 PM
Floor Joists Lifting Off Foundation Walls?! cbeingessner Building & Construction 2 06-12-2008 08:39 AM
Problem with circuit breaker. HELP! spartanic Electrical 2 10-28-2007 03:09 PM
So lost - electrical requirements please help lapsis9 HVAC 4 12-20-2006 08:09 PM
Adding new circuit breakers to 100 amp sub panel DrP Electrical 8 05-25-2006 10:05 PM
