Old 07-14-2011, 08:22 PM   #1
50 AMP Breaker - How many amps per leg?
I am installing a 50 AMP 2 pole breaker for my RV. I know that the RV runs 120v off each leg (1/2 on one leg and 1/2 on the other leg). My question is how many amps run on each leg using this breaker? Is it 50 amps per leg or 25 amps per leg?
Thanks!
vwalla is offline   Reply With Quote
Old 07-14-2011, 08:26 PM   #2
I=E/R
a7ecorsair's Avatar
If you are not drawing any 240 volt power you can draw a max of 50 amps per leg before it will trip.
a7ecorsair is offline   Reply With Quote
The Following User Says Thank You to a7ecorsair For This Useful Post:
vwalla (07-14-2011)
Old 07-14-2011, 08:29 PM   #3
That's what I was thinking, but not being an electrician, did not know. Thanks!
Old 07-14-2011, 08:38 PM   #4
I=E/R
a7ecorsair's Avatar
Question:
Does the RV have a cord with a plug on the end? If so, what does the cable end look like? How many pins - three or four?
Old 07-14-2011, 08:41 PM   #5
4 - 2 hots, 1 neutral, 1 ground.
Old 07-14-2011, 09:16 PM   #6
Electrical Contractor
kbsparky's Avatar
50 per leg.
-KB
Old 07-14-2011, 09:24 PM   #7
Thanks!
Condensor Unit Wiring issues with Square D QO Breaker Perry401 Electrical 19 06-06-2011 10:26 PM
dryer is 27 amps on 30 amp breaker whatrymes Electrical 2 03-30-2011 10:30 PM
Sub-panel selewis Electrical 23 02-21-2010 11:52 PM
Checking a Breaker Klawman Electrical 11 02-18-2010 08:48 PM
Miller syncrowave 250dx Welder installation saddletramp Electrical 6 01-10-2008 02:11 AM
