50 Amp 220 Over 8/3 With Ground To 40 Amp Double Breaker Feeding Into Load Center? - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Old 06-03-2012, 11:13 AM   #31
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
You need to also comply with article 525.
The Following User Says Thank You to Stubbie For This Useful Post:
LooseSCruz (06-03-2012)
Old 06-03-2012, 11:14 AM   #32
Licensed electrician
Rewards Points: 1,296
Flexible cords do not have uninsulated grounds.
As there is nothing to assure that every other circuit is turned off I feel it would be prudent to count the neutral as a CCC. In this case the reduced ampacity would apply.
Old 06-03-2012, 11:15 AM   #33
I am working on a diagram to clarify.....Almost finished please bear with me.
mgambino is offline   Reply With Quote
Old 06-03-2012, 11:15 AM   #34
Originally Posted by mgambino View Post
YES! Was an expression of happiness that someone read my original post that stated 8/3 with ground. The invoice from the electrical supply says 8/3 with ground. I was thinking 8 gauge 3 shielded with one unshielded ground.
You I can forgive for not knowing the terms, but your electrical supply shop ought to know better!
And since I happen to work at a supply shop, I figured that you meant 8/4 because I hear people call it 8/3 with ground all the time. Common mistake.
LooseSCruz is offline   Reply With Quote
Old 06-03-2012, 11:15 AM   #35
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
That's just your opinion. But not a bad one either.
Old 06-03-2012, 11:21 AM   #36
Uploading to my site so I can share image.
Old 06-03-2012, 11:28 AM   #37
http://www.hstrial-gambinoconcessio....o-Gallery.html
Diagram.
Forgive me...I am not a microsoft paint artist. lol
Old 06-03-2012, 11:38 AM   #38
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Now I see a bad plan. You would need to install an inlet on your concession stand not an outlet.
Reason being that the exposed parts on the male cord end will/could be live.
Old 06-03-2012, 11:40 AM   #39
The 50 amp female box is an inlet for the male plug. Am I right about that? Any other issues with the diagram?
Refer to RV wiring to campsites. Keep in mind that campsites provide 30a 110 or 50a 110....thats a difference. But the lead power cord between rv and campsite is the same.
Old 06-03-2012, 12:04 PM   #40
The inlet box needs to be male so you do not have live ends of the cord exposed.
Old 06-03-2012, 12:33 PM   #41
k_buz's Avatar
I have been thinking about this whole neutral as a CCC thing and one thing that wasn't mentioned was that in your OP you are stating the voltage as xxx/220, but I don't remember seeing of it was three phase or single phase.
It is not clear which you actually have, but a three phase service doesnt seem out of the question for this type of setting. If it is a three phase service, you will have to count the neutral as a CCC when using 8/3 W/ground SOW.
Old 06-03-2012, 01:01 PM   #42
You are right. Just had a honda manufacturing electrician look at it. The male into box needs to be female and the box needs to be male. Also.....would be better to run 30 amp main and be well under for the 100 foot run. Thank you.
Old 06-03-2012, 01:02 PM   #43
Single phase.
Last edited by mgambino; 06-03-2012 at 01:06 PM. Reason: Pretty sure the nuetral will be a conductor in this scenario....
Old 06-03-2012, 01:03 PM   #44
Thank you everyone. I will be uploading the corrected diagram (fingers crossed) ...let me know.
Old 06-03-2012, 01:13 PM   #45
Updated diagram>>>>>>>>>>>>>>>>>>>>>>> http://www.hstrial-gambinoconcessio....o-Gallery.html Now will THIS work?
Will leave up for a day or two. Thanks again to everyone for contributing.
Gas line near branch load center pyroarchy Electrical 6 03-03-2012 07:41 AM
Can you drill Load Center? Ralph III Electrical 18 02-24-2012 01:24 PM
Whole house surge protection, help.... Ralph III Electrical 59 01-31-2012 01:37 PM
Main box feeding 220v and 110v brearker box off a 50am breaker? uvamosk Electrical 30 10-14-2009 11:46 PM
Load center vs. bottom fed Panel Board. Ugh. wmldwilly Electrical 8 04-23-2009 08:48 PM
