5-way Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 03-06-2012, 11:59 AM   #1
5-way switch
Is it possible to have a 5-way switch? IE: Four switches and one light.
ÖI donít want to look stupid when I ask my electrician for a 5-way.
bfackrell is offline   Reply With Quote
Old 03-06-2012, 12:03 PM   #2
Rewards Points: 2,516
…I don’t want to look stupid when I ask my electrician for a 5-way.
That can be done. But there is no such thing as a 5-way switch.
Anyway for that setup you would use two 3-way switches and two 4-way switches.
That accomplishes 4 switches for one light.
Heres a video showing 4 switches for one light:
hammerlane is offline   Reply With Quote
The Following User Says Thank You to hammerlane For This Useful Post:
bfackrell (03-06-2012)
Old 03-06-2012, 08:30 PM   #3
" Euro " electrician
frenchelectrican's Avatar
The photo what Hammerlane posted that is my pefered way to do this due it is easy to hook it up and what more you will have netural at each switch box in case you have multi location dimmer switch or electronique timer.
Merci,
Marc
Old 03-07-2012, 09:09 AM   #4
joed's Avatar
Rewards Points: 13,722
And for 5 way you just add another four way switch. You can add as many four way switches as needed.
The Following User Says Thank You to joed For This Useful Post:
bfackrell (03-07-2012)
Wiring in a 4-way Switch RickSene Electrical 6 05-13-2017 04:29 PM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 06:43 PM
1 pole + 3 way switch momof2labs Electrical 1 05-22-2010 10:37 AM
3-way light with a twist Jeepsail Electrical 14 05-18-2010 01:24 AM
4 way switch confusion Richo Electrical 10 04-09-2009 07:11 AM
