5 Volt VS 10 Volt AC Charger - Electrical - DIY Chatroom Home Improvement Forum
Old 03-23-2011, 02:12 PM   #1
Hi,
I have an iPad and and Android smartphone. The charger for the phone is a 5V AC charger, and the iPad's is a 10V AC charger. They are USB wall chargers, so I can interchange the cable to fit either device. I wanted to know if it's safe to do so, or would I be overloading the phone, which came with the lower voltage charger? I've tried charging the iPad with the 5V as well as my 12V car charger, and it seems to work fine. As long as the charger outputs enough amps it should be OK to use with any electrical device right?
Thanks!
cu2cool is offline   Reply With Quote
Old 03-23-2011, 04:12 PM   #2
I=E/R
a7ecorsair's Avatar
The chargers should state their output somewhere on the transformer. If one is 10V DC and the other is 5V DC then they are not interchangeable. What does the operator's manual say about charging?
The USB standard supports 5V. Haven't heard about USB supporting 10V.
a7ecorsair is offline   Reply With Quote
12 Volt lighting AC or DC johnr9q Electrical 20 11-21-2010 02:12 PM
Want to change a single 240 volt circuit with only one outlet, to a 120 volt circuit with a standard 120 volt outlet. covenant Electrical 7 11-09-2010 07:07 PM
90 amp electric car charger! The future... Billy_Bob Electrical 16 02-16-2010 03:01 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 10:41 PM
modify battery charger geeyathink Electrical 1 08-03-2006 05:36 AM
