5-15p Female - Electrical - DIY Chatroom Home Improvement Forum
Old 08-09-2012, 12:47 AM   #1
Rewards Points: 512
5-15p Female
What type receptacle (NEMA #) will this female plug mate with? Does the receptacle need to be in a disco box of some sort?
https://lh4.googleusercontent.com/pu...j46oX3XsTkR5is
EDIT: This is for a glass case which has fluorescent lights.
Old 08-09-2012, 06:38 AM   #2
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
What does the cord end you linked to go on?
Old 08-09-2012, 07:51 AM   #3
joed's Avatar
Rewards Points: 13,762
That is a standard 15 amp receptacle. It is not the power inlet. It is a power outlet. The part that plugs into the wall will look like any other 15 amp plug.
Old 08-09-2012, 09:44 AM   #4
Rewards Points: 512
It's for a glass case which has fluorescent lights.
Old 08-09-2012, 09:48 AM   #5
Rewards Points: 512
A standard receptacle? It's on the end of the cord going to a glass case. I'm assuming it's the cord for the fixture.
Old 08-09-2012, 01:44 PM   #6
joed's Avatar
Then the fixture has a normal 5-15P plug on the end of it.
That's a 5-15R. Note the R for receptacle or female end. The plug/male end is a 5/15P. Note the P. It is just a standard 15 amp single receptacle like you have in the wall. That is not where the power connects to the wall. There must be another end that plugs into the wall. It is basically a build in extension cord.
The Following User Says Thank You to joed For This Useful Post:
sirsparksalot (08-10-2012)
Cpvc female adapter w/ o-ring crza1 Plumbing 12 02-16-2012 05:28 PM
Female with Basement Flooring Question smilekl Flooring 0 02-14-2012 02:12 PM
female L14-30 to female 6-20 GLS0628 Electrical 7 12-21-2011 05:40 PM
older female plumbing an old house from the 40's Fern Senti Plumbing 1 04-19-2011 12:41 AM
Can't stop leak at 3/4" NPT steel male to brass female HVAC_NW Plumbing 10 10-28-2010 11:38 PM
