5 Or 10 Amp Breaker? - Electrical - DIY Chatroom Home Improvement Forum
Old 08-12-2011, 01:08 AM   #1
Rewards Points: 264
5 or 10 amp breaker?
Can you get a 5 or 10 amp thin breaker for a GE panel box? What about put a breaker right outside the panel box, like this?
http://cgi.ebay.com/Altech-5-Amp-480...item43a8701c4e
Looking for a way to run high gauge wire safely but it seems like all I'm seeing is 15 amp breakers and up.
tibberous is offline   Reply With Quote
Old 08-12-2011, 01:36 AM   #2
Rewards Points: 6,652
What are you tring to power?
Old 08-12-2011, 01:41 AM   #3
Rewards Points: 264
One lightbulb.
Old 08-12-2011, 02:52 AM   #4
Rewards Points: 1,192
Check your code about minimum branch circuit ampacity,and if it needs to be afci or gfic .
bobelectric is offline   Reply With Quote
Old 08-12-2011, 07:37 AM   #5
I=E/R
a7ecorsair's Avatar
Originally Posted by tibberous View Post
One lightbulb.
Keep in mind that the breaker isn't there to protect the light bulb, the breaker is sized to protect the wire for the circuit it supports.
a7ecorsair is offline   Reply With Quote
Old 08-12-2011, 07:44 AM   #6
seansy59's Avatar
Rewards Points: 258
I agree with previous post. A circuit breaker will do "squat" with protecting a light or appliance. It is there to protect the run of wire by its gauge and amperage load.
I would just use a 15 amp breaker with 14 gauge wire for a light. Your not saving money really by going a different route.
15 amp- 14gauge wire
20 amp- 12gauge wire
I see no reason why 1 lightbulb can't be on a dedicated circuit. Its really the safest route to me having everything seperate to prevent overloading. Although, its impossible when you add things up in most cases
Note: If the light is going to be switched on/off alot, put a toggle lightswitch in between the breaker and light. Breakers are not meant for being switched on/off/on/off/on..........it's against code to use it for that.
seansy59 is offline   Reply With Quote
Old 08-12-2011, 07:45 AM   #7
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,948
One lightbulb.
Doesn't matter what it is protecting.
Listen to the others.
The breaker protects the wire, NOT the load.
The smallest branch circuit is 15A, which is typically 14ga wire.
Speedy Petey is online now   Reply With Quote
Old 08-12-2011, 08:00 AM   #8
Learning by Doing
Leah Frances's Avatar
Wouldn't it be easier to tap off another branch circuit with JBox and a switch to put a light in?
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 08-12-2011, 11:44 AM   #9
Rewards Points: 264
Yeah, what I was really wanting to do was just run it with 18 gauge wire or higher, but didn't want to use 18 gauge on a 15 amp breaker and risk it burning up. Probably just going to do it with 14 gauge if it's going to be a lot of work doing it the other way.
Old 08-12-2011, 11:51 AM   #10
" Euro " electrician
frenchelectrican's Avatar
I am sorry but you have to use standard 14 gauge conductor or cable for branch circuit that is the smallest they will allowed in the NEC.
And the smallest one typicaly use is 15 amp breaker as well.
Merci,
Marc
Old 08-12-2011, 01:24 PM   #11
In a DC circuit with stranded wiring, but it does not fly with AC wiring circuits.
Old 08-12-2011, 10:39 PM   #12
Semi-Pro Electro-Geek
Rewards Points: 2,922
Many breakers are rated for "switch duty" and are labeled "SWD". They are intended for exactly this purpose - switching lighting circuits on and off.
mpoulton is offline   Reply With Quote
Wiring Size Calculations for New Service CorinthWest Electrical 7 12-07-2010 11:36 AM
Replacing a circuit breaker tertius Electrical 9 09-24-2009 08:17 PM
Replacing and Moving a Fuse box with a breaker box nightrook Electrical 18 09-24-2009 07:49 PM
I can "double" the wires to each breaker in my breaker panel right? Piedmont Electrical 40 10-01-2008 11:18 AM
Outdoor breaker panel questions lhoney2 Electrical 12 07-19-2007 05:44 PM
