4x4 Ceiling Box Max Cable Entries - Electrical - DIY Chatroom Home Improvement Forum
Old 10-31-2011, 02:35 PM   #1
Rewards Points: 1,062
Question
4x4 ceiling box max cable entries
what is the maximum # of cables entering and exiting a square 4x4 ceiling box, such as what is commonly used for lights and ceiling fans? is 5 too many? it does have 5 knockouts but was thinking it's too much wire inside a small box.
Old 10-31-2011, 03:31 PM   #2
Sparky
Rewards Points: 510
http://www.google.com/products/catal...ed=0CFEQ8gIwBA
that box?
depends on how deep and what gauge wire
each #14 is 2 cu in, # 12 is 2.25 all grounds count as one wire
1.5" deep is 15.8 ci
2 1/8" deep is 22.5 ci
Techy is offline   Reply With Quote
The Following User Says Thank You to Techy For This Useful Post:
amakarevic (10-31-2011)
Old 10-31-2011, 04:46 PM   #3
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,968
The cable entries are irrelevant. As Techy said, it goes by volume.
The Following User Says Thank You to Speedy Petey For This Useful Post:
Old 10-31-2011, 11:00 PM   #4
but i guess i could always go with an extension. all the 5 cables coming in are 14/2. so, if i use a 4x4x1.5 octagonal box with an extension that is that much, that is 48 ci, if the box was rectangular, knock off e.g. 5 for each one for the cut corners, that would be down to about 38 cu. 38/2 = 19 and i have 15 total (5 cables x 3 wires each cable), so i am good to go.
thanks
Old 10-31-2011, 11:16 PM   #5
Code05's Avatar
Rewards Points: 1,104
All grounds count as one. Five 14/2s is 11 x 2=22. Are you using built-in internal or external clamps?
Techy made a typo 4 x 2 1/8 is 21.5
Code05 is offline   Reply With Quote
Old 10-31-2011, 11:34 PM   #6
liscenced electrician
Rewards Points: 538
how many wires fit in a 22cu/in box?................ All of them
jimmy21 is offline   Reply With Quote
Old 11-01-2011, 05:08 AM   #7
Sparky
Rewards Points: 510
page 15
http://www.tnb.com/contractor/docs/sc_indoorboxes.pdf
Old 11-01-2011, 06:25 AM   #8
Licensed electrician
Rewards Points: 1,744
An octagonal 8B box 1 1/2" deep has a volume of 15.5 according to Table 314.16(A).
Also remember that any cable would need to have the conductors extend 3" past the face of any extensions added to the box.
Old 11-01-2011, 11:05 AM   #9
Code05's Avatar
Originally Posted by Techy View Post
I stand corrected, I used the volumes in T314.16.
Interesting, Raco lists their box volumes the same as the table.
Old 11-01-2011, 04:50 PM   #10
Sparky
Rewards Points: 510
it may be a typo on T&B's part aswell..
Old 11-01-2011, 06:49 PM   #11
Code05's Avatar
I think you may be correct. Here is a more modern T&B catalog and the box sizes match T314.16.
http://www.tnb.com/ps/endeca/index.c...t=&Ntk=&parts=
Short ciruit with Romex 10/3 cable and cable connectors virago Electrical 21 10-07-2011 08:01 AM
BX Cable and tin ceiling brookny Electrical 4 09-18-2011 11:31 AM
replacing a 7'6" ceiling for a Split-foyer home czellerhoff Building & Construction 1 10-16-2010 11:36 AM
Sagging ceiling timbo59 Drywall & Plaster 8 07-02-2010 12:15 PM
can't get new light fixture to work carolcwilson Electrical 24 08-12-2008 12:52 PM
