480 Voltage To 200 Amps - Electrical - DIY Chatroom Home Improvement Forum
Old 07-31-2007, 10:18 PM   #1
Question
480 voltage to 200 amps
If someone can help me. I have a business and have been told 10 different things by different electricians. I have 100 amp service comming into my building with 480 volts and then running through a 480 3 phase transformer.
Does that mean or is it possible to turn that 100 amps into 200 amps? Thanks if you can give me any info.
girl who needs info is offline   Reply With Quote
Old 08-01-2007, 05:48 AM   #2
Master Electrician
JohnJ0906's Avatar
480v x 100 amps x 1.73 = 83,040 VA.
83,040 VA / 208v / 1.73 = 230.76 amps at 208/120v 3 phase
I am assuming a 3 phase system, stepped down from 480 3 ph to 208/120 3 ph.
John from Baltimore
One Day at a Time
"Experience is what you get when you were expecting something else"
"The bitterness of low quality lingers long after the sweetness of low cost is forgotten"
JohnJ0906 is offline   Reply With Quote
Amps vs wattage moneymgmt Electrical 8 05-30-2007 08:13 PM
splitting 200 amps, help with parts please tuolumne Electrical 2 03-30-2007 01:09 PM
does the neutral have a voltage? hvactech Electrical 3 03-12-2007 06:05 PM
Low voltage to vacuum l.schrankel@comcast.net Electrical 2 03-04-2007 10:38 AM
Which low voltage wire scozzer Electrical 2 02-18-2007 11:56 PM
