45 A Issues!! - Electrical - DIY Chatroom Home Improvement Forum
Old 09-25-2007, 05:05 AM   #1
45 A issues!!
Hiya there - am new on here so please forgive my ignorance with anything electrical - but a have a bit of a query that i am hoping someone may be able to help me with:
I have an industrial washing machine which has a 45A heating element - what do i do to allow this to run via my 13 A plug as (naturally) it doesnt like it atm!
Thanks in advance
Mackers
Mackers is offline   Reply With Quote
Old 09-25-2007, 05:35 AM   #2
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
I have no idea what your asking. Are you in the USA? If your asking how to connect a commercial washer with 45A heating element into a 15 amp circuit that would make for some degree of sense.
Answer is.. gotta have a tad bit more information to get you pointed in the right direction.
What are the voltage requirements of this washer? It should have a nameplate give us everything on it.
Stubbie
Old 09-25-2007, 05:49 AM   #3
Stubbie - sorry of the ambiguity - yes i am asking how to connect a commercial washer with 45A heating element into a 13 amp circuit , but am in the UK,
Old 09-25-2007, 05:55 AM   #4
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,950
YOU DO NOT! Period.
I truly do not mean to be rude, but this should be obvious.
You need a new circuit run for the washer.
Speedy Petey is online now   Reply With Quote
Old 09-25-2007, 05:58 AM   #5
Ur right ur not being rude - but i have no idea - one chap told me i need a transformer - but i just thought i would get someone else idea!
I know nothing about electrics - hence the apparant stupid question
Old 09-25-2007, 08:02 AM   #6
UAW SKILLED TRADES
Stubbie's Avatar
Like Speedy said you can't do this. I was really waiting to find out if you were in the USA. Amps are amps no matter where you are located. I not sure if anyone here is familiar enough with your wiring to help you. The website is in the USA. Might watch the thread and see if one of the guys can answer your question and tell you what you need but posting the nameplate information is a good start.
Stubbie
Old 09-25-2007, 04:21 PM   #7
Here is something someone said I could post on his behalf. I'd rather not get in the middle so I'll leave it at this. OK?
(You) need a Radial circuit direct from his consumer unit wired in min 10.0 T&E 6242Y sheathed cable. Wire to a 60amp DP local Isolator and at the consumer unit end a 50amp Type B mcb.
16mm T&E and 63amp rated throughout would be better but the 50 amp circuit should cover well enough.
Electrical issues with home inspection toolmaan Electrical 20 08-10-2007 05:52 PM
Murray rider issues BigJoe Landscaping & Lawn Care 1 07-12-2007 06:26 AM
Issues with appliance plug hgiljr Electrical 1 03-17-2007 07:09 AM
Grounding Issues in a 1849 House Contractor's_Daughter Electrical 6 11-20-2006 10:56 AM
