400 Watt High Pressure Sodium Light - Electrical - DIY Chatroom Home Improvement Forum
Old 11-03-2012, 03:31 PM   #1
400 Watt High Pressure Sodium light
What I would like to know is if my 30 amp 120V electrical outlet box, using only the plug from an 400 Watt High pressure light bulb and going through a digital ballast be enough amps for it.
jstorkson is offline   Reply With Quote
Old 11-03-2012, 06:30 PM   #2
Julius793's Avatar
What's the setup? A 400w hps can be on a 1(a circuit.
Electricity will kill you if you give it a chance
Julius793 is offline   Reply With Quote
Old 11-03-2012, 07:09 PM   #3
Idiot Emeritus
Rewards Points: 1,492
A 400 watt HPS will need somewhere around 4 amps at 120.
micromind is offline   Reply With Quote
Old 11-03-2012, 07:22 PM   #4
Rewards Points: 12,790
30 amp. 110 volt outlet
Old 11-03-2012, 07:50 PM   #5
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
General lighting/receptacles cannot be on a 30A circuit.
Old 11-03-2012, 08:09 PM   #6
400 watt HPS light
I would like to thank all that replyed
Old 11-04-2012, 01:22 AM   #7
" Euro " electrician
frenchelectrican's Avatar
Also let me add this info along the way with 400 watt HPS ballast you will have to double check the ballast connection on the primary ( incomming ) side to use the correct tap due some of the ballast are mulit voltage unit which it mean it can run few differnt voltage so therefore it can run 120,208 ,240,277 volts ( some case 480 volts )
Also if any taps are not used please make sure they are wirenutted or shrinktube on it to prevent any short.
And double check the ballast info for the correct lamp as well ( make sure they are matched up )
Merci,
Marc
High pressure operating Sdeclara HVAC 13 01-17-2012 03:44 PM
Grout question poolecw Flooring 11 10-29-2008 08:32 PM
High pressure bjr23 Plumbing 1 03-27-2007 08:24 PM
High pressure in water line atlfiveo Plumbing 5 02-06-2007 10:04 PM
How high for front light? Not Sure Electrical 2 08-07-2006 12:37 AM
