-   -   400 Watt High Pressure Sodium light (http://www.diychatroom.com/f18/400-watt-high-pressure-sodium-light-162051/)
jstorkson 11-03-2012 03:31 PM
What I would like to know is if my 30 amp 120V electrical outlet box, using only the plug from an 400 Watt High pressure light bulb and going through a digital ballast be enough amps for it.
Julius793 11-03-2012 06:30 PM
What's the setup? A 400w hps can be on a 1(a circuit.
micromind 11-03-2012 07:09 PM
A 400 watt HPS will need somewhere around 4 amps at 120.
joecaption 11-03-2012 07:22 PM
30 amp. 110 volt outlet:eek:
k_buz 11-03-2012 07:50 PM
General lighting/receptacles cannot be on a 30A circuit.
jstorkson 11-03-2012 08:09 PM
400 watt HPS light
I would like to thank all that replyed
frenchelectrican 11-04-2012 01:22 AM
Also let me add this info along the way with 400 watt HPS ballast you will have to double check the ballast connection on the primary ( incomming ) side to use the correct tap due some of the ballast are mulit voltage unit which it mean it can run few differnt voltage so therefore it can run 120,208 ,240,277 volts ( some case 480 volts )
Also if any taps are not used please make sure they are wirenutted or shrinktube on it to prevent any short.
And double check the ballast info for the correct lamp as well ( make sure they are matched up )
Merci,
Marc
