400 Foot Run - Electrical - DIY Chatroom Home Improvement Forum
Old 11-11-2013, 06:27 PM   #1
400 foot run
I was wondering if it is possible to run 12/2 wire on a 20amp breaker for a run of 400 feet. I want to put about 4 lights or even 2 lights (60 watts) around my pond to play hockey. I realize the voltage will drop and it does not have to be 100% efficient. Any lighting is better than nothing at this point.
Thank you
PondHockey is offline   Reply With Quote
Old 11-11-2013, 06:33 PM   #2
Mad Scientist
Even with 4x60W lights, you'd be using about 2A of current, your voltage drop at that distance will be under 3%. No problem at all.
McSteve is offline   Reply With Quote
Old 11-11-2013, 06:34 PM   #3
PoleCat's Avatar
Rewards Points: 1,646
If all you need is lights then no problem. Electric motors suck extra current and get hot under those conditions but incandescent lights don't.
"Ask me anything. If I don't know the answer I'll make something up."
PoleCat is offline   Reply With Quote
Old 11-11-2013, 06:36 PM   #4
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Thank you
that would be a 2 amp draw and incur a 3.58% voltage drop at that distance, I would still pull 10-3 UF and split the load in half, because no way is 240 watts of light going to do you any justice for playing hockey…..
Old 11-11-2013, 06:37 PM   #5
E2 Electrician
Its still a problem, voltage drop must be still taken into consideration….
The Following User Says Thank You to stickboy1375 For This Useful Post:
Philly Master (11-12-2013)
Old 11-11-2013, 06:51 PM   #6
I am on a tight budget. So any lights is better than no lights. I will most likely be playing with my two sons. No hardcore hockey. The pond is about 40*75 feet. Even two lights would work or would be better than nothing.
Old 11-11-2013, 06:58 PM   #7
E2 Electrician
Buy 240v lights, you can find super deals on them online…
Old 11-11-2013, 08:46 PM   #8
Rewards Points: 1,016
Maybe LED lighting.
____________
Vince
Old 11-11-2013, 08:59 PM   #9
deverson's Avatar
Rewards Points: 77
2-250 wt quartz floodlights would give you 112 volts at 400 ft. Resistive load so not much different than putting them on a dimmer. Not a great situation but you have to take care of the hockey players!
It is over the informational note for voltage drop but it's not a supercomputer either.
deverson is offline   Reply With Quote
Old 11-11-2013, 11:55 PM   #10
seansy59's Avatar
Rewards Points: 258
Use 2-3 of these.
It'll become day time...
http://www.amazon.com/TSSS-Spotlight...ywords=50w+led
seansy59 is offline   Reply With Quote
Old 11-12-2013, 07:43 AM   #11
Thanks guys. I am going to go with LED lighting possibly two of them. Once I get my rink going I will come back and post results to help others in the future.
Old 11-12-2013, 09:47 AM   #12
Electrical Contractor
Philly Master's Avatar
Rewards Points: 516
the LED lights for what you are doing ... well IMHO do not work well ... PERSONAL experience ....
Philadelphia Master Electrician-Generac Dealer
Philly Master is offline   Reply With Quote
Any thoughts on hanging a foot pedal on porch swing? tabatt07 General DIY Discussions 1 07-25-2012 04:54 PM
dry water line to the foot valve ksbnellis Plumbing 0 06-06-2011 11:37 PM
Build 10 foot wall with 5 foot 2x4's Gandalf Carpentry 22 12-08-2009 09:50 PM
Check valve and foot valve on same well feed? rtoni Plumbing 4 06-04-2009 09:42 AM
Over 8 Foot Wall - Method of Applying Sheathing... MoparAutoworks Building & Construction 14 08-20-2006 07:38 PM
