400 Foot Electric - Electrical - DIY Chatroom Home Improvement Forum
Old 07-20-2010, 09:34 PM   #1
400 foot electric
what would be the most cheap and efficient way to run electricity to a shed about 400ft away (100 meters) continuously? I will, for the most part, be powering lights and maybe a drill (MAYBE).
Bill
Bgm94 is offline   Reply With Quote
Old 07-20-2010, 09:42 PM   #2
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
define cheap.
As I define cheap, there is no cheap method to get power 400 feet.
other than that, some large cable (#2 cu or 1/0 al)
Old 07-20-2010, 09:47 PM   #3
A 5% drop at 6 A at 120 V allows 1 ohm max. For an 800' round trip with copper, for just voltage drop considerations, it's #8 or thereabouts, but most people advise you'll be asking for more power later.
Old 07-20-2010, 09:51 PM   #4
could someone please link me to what i need, and what i need to do exactly
Old 07-20-2010, 09:52 PM   #5
nap
You talking to me?
nap's Avatar
Originally Posted by Yoyizit View Post
A 5% drop at 6 A at 120 V is 1 ohm. For an 800' round trip it's #8 or thereabouts, but most people advise you'll be asking for more power later.
so you are suggesting a 6 amp breaker?
If he is going to run a 20 amp circuit, he should use large enough wire to carry most of the circuit capacity.
and at a 6 amp load you would need #6 (cu) to remain below the recommended 3% voltage drop.
Since we are talking about a drill (electrical motor) the start current is going to be considerable higher than the running current.
Old 07-20-2010, 09:57 PM   #6
That motor surge seems to be incorporated in the 3% or 5% limit, the so-called supply "stiffness."
Old 07-20-2010, 10:12 PM   #7
nap
You talking to me?
nap's Avatar
Huh?
current is current. If current goes up, it will cause a greater voltage drop.
Old 07-20-2010, 11:17 PM   #8
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
You pretty much have to figure a 120 volt circuit at 800 feet round trip and you need to figure 20 amps in my opinion to do what the Op wants. If you consider a 20 amp multiwire circuit there would be some benefits to VD but you will need to practice load balancing on the hot legs.
Just the same the wire needs to be large enough to handle 20 amps calculated on a 120 volt circuit.
The distance creates a few problems due to wire size and possibly the biggest is the cost of the wire depending on the OP's budget.
That wire size is likely to put you into a pvc conduit wiring method with thwn wires.
Anyway I don't see 'cheap' in getting 20 amps 400 feet. There are several things that need to be considered when you have to upsize wire for that kind of distance to kill the VD.
To get to 'cheap' you might be better off to move the shed closer to the supply point ... say about 200 feet......
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
Old 07-21-2010, 12:51 AM   #9
" Euro " electrician
frenchelectrican's Avatar
for little over 100 meter you denfine need at least 35mm˛ { #2 CU } or larger conductors that for a single 20 amp circuit.
The other issue will come up very fast here is the termation try to go from 35mm˛ to 4.0mm˛ { #12 AWG } to hook up the breaker you will need either split bolt or polairs tap connector block.
And yeah you will need oversized junction box at the shed side but for house side if you are landing at the load centre it is not too bad.
Also if you want to go with alum verison you have to bump up one size larger.
They are little cheaper but how much it depending on what it have on stock and what specal order.
Merci.
Marc
Old 07-21-2010, 08:17 AM   #10
Licensed electrician
Rewards Points: 1,876
Nap, the so-called supply "stiffness." is the opposite of voltage droop. It is caused by using a blue conductor.
Please get help if this condition lasts longer than 4 hours.
J. V. (07-21-2010)
Old 07-21-2010, 10:00 AM   #11
nap
You talking to me?
nap's Avatar
thanks Jim. I must have missed that in my apprenticeship.
Old 07-21-2010, 10:57 AM   #12
Electrician
Proby's Avatar
Normally for detached garages I like to install 100A sub panels, or at the very least 2X 20A circuits. However, sometimes the homeowner truly does only want a light or two and a battery charger or drill.
A 100A sub panel at 400' wouldn't work out too well for the thread starter As long as his drill is variable speed, maybe he is alright with just running 8-2 UF cable Altho it's still no where near "cheap"
Proby is offline   Reply With Quote
Old 07-21-2010, 11:11 AM   #13
Actually if you run #6 wire for a 20a 240v small sub that will work
Voltage drop 3.2%
Or a 30a sub would work with #4 wire
Old 07-21-2010, 04:53 PM   #14
Rewards Points: 502
to be honest 400' of any wire wont be cheap, move your shed closer
if you really only want to run a couple of incandecent lights, I bet even 12 gauge would do. Everyone always talks about the 3% drop standard, but I bet the OP could get by with a 25% VD. the bulbs will be a little dimmer and the drill will turn a bit slower, but it will all work.
I think we've all played the lets see how many extention cords we can string together at one time or another, and for the most part the stuff at the other end still works. I've never taken it 400' but but I have run a cememnt mixer with about 200 feet of cord before, and that coming from a house thats a bit low on voltage to begin with because its a ways from the transformer. 12 gauge is heavier than the standard extention cord.
run 8x 50' extention cords together as a test if you want first. either way, you'll be set for outdoor extention cords.
forresth is offline   Reply With Quote
Old 07-21-2010, 05:23 PM   #15
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,992
Hire an electrician.
www.electrician.com
Tags
electrical , lights , shed , wiring
String trimmers - gas, corded electric, or battery electric - which one?? whataboutj Landscaping & Lawn Care 43 05-01-2010 09:25 AM
90 amp electric car charger! The future... Billy_Bob Electrical 16 02-16-2010 02:01 PM
Build 10 foot wall with 5 foot 2x4's Gandalf Carpentry 22 12-08-2009 09:50 PM
Is my panel sufficient to add Electric water heater andy Electrical 16 04-21-2009 08:34 AM
Over 8 Foot Wall - Method of Applying Sheathing... MoparAutoworks Building & Construction 14 08-20-2006 07:38 PM
