400 Amp Meter Socket Upgrade, Can I Re-use Existing Metered Panel? - Electrical - DIY Chatroom Home Improvement Forum
Old 04-06-2012, 02:10 AM   #1
I am doing a service upgrade from 200 Amp to a 400 Amp service. The existing service is an all in one 200 Amp metered service panel. The plan is to install a new 320/400 Amp socket meter and install a second 200 Amp panel.
My question is, am I able to remove the meter from the existing 200 Amp panel and still use it with the new service by placing a meter cover socket blank on the meter socket? If I am able to re-use the existing panel is there anything else I should be aware of?
Thanks in advance.
Mark
macp123 is offline   Reply With Quote
Old 04-06-2012, 02:47 AM   #2
Electrical Contractor
kbsparky's Avatar
Most CSED boxes can NOT be used as a sub-panel, since the neutral is permanently bonded to the can.
You may have to change it to a regular load center, or install a separate isolated neutral bar assembly.....
-KB
The Following User Says Thank You to kbsparky For This Useful Post:
plummen (04-06-2012)
Old 04-06-2012, 07:57 AM   #3
When you say I may have to change it to a regular load center, what exactly do you mean? How would someone go about doing it code wise?
Old 04-06-2012, 09:08 AM   #4
up-grade service
no- not unless panel is rated for 400 amps ?
shockme123 is offline   Reply With Quote
Old 04-06-2012, 09:16 AM   #5
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Why would the panel need to be rated for 400A? It would be protected by its own OCPD.
The Following User Says Thank You to k_buz For This Useful Post:
Old 04-06-2012, 12:40 PM   #6
kbsparky's Avatar
THis means you remove the existing meter/panel combo, throw it away, and then install a new regular panel in its place ....
-KB
Old 04-06-2012, 02:04 PM   #7
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,948
Multiple Panel Question theatretch85 Electrical 7 09-29-2016 07:15 PM
Wires through meter socket enclosure ddellario Electrical 3 03-03-2012 04:41 PM
100A to 200A upgrade Photos. Please provide any feedback. mcnutter1 Electrical 14 01-23-2012 01:18 PM
3 Phase meter socket question a320200 Electrical 4 12-11-2009 12:45 AM
meter to service panel mikim Electrical 5 05-04-2007 05:34 AM
