40 Amp GFCI Breaker Panel - Electrical - DIY Chatroom Home Improvement Forum
Old 09-15-2008, 02:17 PM   #1
Can I use a 40 Amp GFCI Breaker Panel on my hottub? I will have a 60 Amp breaker in my house, what will that do for power problems if any?
Chad is offline   Reply With Quote
Old 09-15-2008, 02:55 PM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,948
What does the tub require???
What size wire was used?
WHO did the install?
Speedy Petey is online now   Reply With Quote
Old 09-15-2008, 03:06 PM   #3
The tub requires 60 Amps, will this 40 Amp GFCI panel affect the tub over time. The proper wiring (6-3 Ground wire) has been used?
Old 09-15-2008, 03:46 PM   #4
joed's Avatar
Rewards Points: 12,446
If the tub requires 60 amp then it is likely to trip a 40 amp gfci.
Old 09-15-2008, 03:53 PM   #5
I will go back to my contractor, good to know before we do power up. Thank you very much.
Old 09-15-2008, 04:34 PM   #6
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
Assuming you have all the accessories...heater(s), jet pumps etc. that make the tub require 60 amps then a 40 gfci won't get it. I am wondering why an electrical contractor, if thats who did the install, would put a 40 amp gfci panel on a 60 amp branch circuit requirement??
Old 09-15-2008, 05:16 PM   #7
6/3 wg? What type of wire is run to the hot tub? Is it in conduit?
jerryh3 is offline   Reply With Quote
Old 09-15-2008, 05:23 PM   #8
Electrician
Inquiring minds want to know!
chris75 is offline   Reply With Quote
Old 09-15-2008, 05:57 PM   #9
2 to 1 it's 6/3 UF. Any takers?
Old 09-15-2008, 06:06 PM   #10
No. I'd rather keep my 1.
Old 09-15-2008, 06:14 PM   #11
That's no fun. How about for some bonus points we'll bet if it was inspected or not?
Old 09-15-2008, 06:21 PM   #12
Electrician
I'm going with NM in conduit myself.
Old 09-15-2008, 07:22 PM   #13
Rewards Points: 266
"But that's what the guy at home depot said.."
junkcollector is offline   Reply With Quote
New GFCI Breaker Tripping w/ 3-way Flourescents BigJimmy Electrical 8 12-29-2008 02:29 PM
Installing new (service?) breaker panel and generator panel Nhrafan Electrical 6 04-01-2008 03:03 PM
Circuit breaker panel - Advice needed justtired Electrical 15 12-13-2007 05:55 AM
20 Amp Breaker tripping with GFCI panhandlion Electrical 7 12-12-2007 08:59 PM
Outdoor breaker panel questions lhoney2 Electrical 12 07-19-2007 05:44 PM
