4 Wires: 2 Hot. What To Do? - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 06-24-2011, 08:03 PM   #16
Nope, not ceiling. I'm using incorrect language. Buzzing is coming from the light, or around the light, on the wall above the switch. It might even be coming from the switch itself but it's hard to tell as they are very close. It only happens when the light is dimmed, when it's fully on the buzzing is gone.
Stacie is offline   Reply With Quote
Old 06-24-2011, 08:12 PM   #17
Electrical Contractor
jbfan's Avatar
Rewards Points: 530
Try changing the lamp inside the fixture.
Cheaper lamps can cause a dimmer to buzz.
The Following User Says Thank You to jbfan For This Useful Post:
Stacie (06-24-2011)
Old 06-24-2011, 10:46 PM   #18
if it's humming, shut the power off to the dimmer or disconnect a wire till the buzzing stops and we can talk tomorrow. yes, you need a volt meter you can read numbers on. harbor freight has them for about three dollars. a week or two ago they were giving them away as a door gift. thanks, budro
buddy builder is offline   Reply With Quote
Old 06-24-2011, 10:50 PM   #19
i just read jbfan's reply. he could be right. i didn't know it was okay when on all the way. if you have a newer curly q bulb that may be your problem now. thanks, budro
Old 06-25-2011, 12:25 AM   #20
Buzzing from the switch is normal with "old" dimmer's, as in not digital. Does the buzzing go away when the light is at full brightness? Buzz's when it's dimmed?
If so it's the internal resistor built into the dimmer that's buzzing.
Haligonian is offline   Reply With Quote
The Following User Says Thank You to Haligonian For This Useful Post:
Stacie (06-25-2011)
Tags
dimmer , electric
D 3 number 12 wires equal one number 8 wire? Uncle Wayne Electrical 3 01-26-2011 08:00 PM
if there are red white green and black wires coming out of your walls like everywhere cray331 Electrical 3 01-17-2011 12:56 PM
240v conduit with different gauge wires... Biospot Electrical 7 12-14-2010 07:07 PM
Removing wall with wires in it jboswald Electrical 11 11-29-2009 02:55 PM
Three hot wires coming into a receptacle? Jeff DIY Electrical 10 10-07-2009 01:35 PM
