4 Wire Range Hook Up On 220 Outlet - Electrical - DIY Chatroom Home Improvement Forum
Old 08-11-2011, 12:23 AM   #1
4 wire range hook up on 220 outlet
witch is the hot terminal on the outlet the wite or copper one and is the wite wire a hot wire and is the black a hot wire what is the gray one for
greenhorn1 is offline   Reply With Quote
Old 08-11-2011, 04:34 AM   #2
Rewards Points: 1,192
Your question is as clear as a lost golfball in high cotton!
bobelectric is offline   Reply With Quote
The Following User Says Thank You to bobelectric For This Useful Post:
gregzoll (08-11-2011)
Old 08-11-2011, 07:39 AM   #3
Rewards Points: 1,216
You really shouldn't be doing this job yourself.
COLDIRON is offline   Reply With Quote
Old 08-11-2011, 08:05 AM   #4
Master Electrician
Rewards Points: 3,778
That would be a white golf ball, yes?
brric is offline   Reply With Quote
Old 08-11-2011, 09:21 PM   #5
Electrical Contractor
kbsparky's Avatar
All the wires (Black, Red, White) are current-carrying conductors. The green wire only serves as a grounding means, and is not part of the regular circuitry.
Clear as mud?
-KB
The Following User Says Thank You to kbsparky For This Useful Post:
greenhorn1 (08-11-2011)
Old 08-11-2011, 10:54 PM   #6
kbsparky
thanks for not being rude you are a big help
Old 08-11-2011, 11:31 PM   #7
dmxtothemax's Avatar
Rewards Points: 5,108
I would guess that white is one hot,
And black is another hot,
If it is set up for 240v.
As for the grey ???
Possibbly a neutral,
But you need to double check this first.
Meter across grey and black = 120v.
Meter across grey and white = 120v.
This would indicate the truth.
But if you have any doubts,
Get an electricain,
Dont take chances with 240v
doubily dangerous.
dmxtothemax is offline   Reply With Quote
Old 08-12-2011, 08:50 AM   #8
I=E/R
a7ecorsair's Avatar
I think the guys were just having some fun...
Come back and give us a better description of your project. You may have a picture in your mind of what it looks like but we can't see your project so that is why it is important to lay things out so we can see it
1) Tell us why you are doing this - is it a new range replacing an older unit?
2) Is there an existing wall receptacle and does it have three pins or four pins?
3) Is the cord already attached to the range?
a7ecorsair is offline   Reply With Quote
2 wire switch connected to 3 wire outlet pacowboy78 Electrical 4 08-23-2010 08:25 PM
Adding ground in old home ChaosTheory Electrical 6 06-16-2010 05:02 PM
range wire 7echo Electrical 5 08-17-2009 01:53 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 10:41 PM
Electrical outlet hook up. helpless handyman Electrical 4 07-30-2007 09:18 PM
