-   -   4 wire range hook up on 220 outlet (http://www.diychatroom.com/f18/4-wire-range-hook-up-220-outlet-113658/)
greenhorn1 08-10-2011 11:23 PM
witch is the hot terminal on the outlet the wite or copper one and is the wite wire a hot wire and is the black a hot wire what is the gray one for
bobelectric 08-11-2011 03:34 AM
Your question is as clear as a lost golfball in high cotton!
COLDIRON 08-11-2011 06:39 AM
You really shouldn't be doing this job yourself.
brric 08-11-2011 07:05 AM
That would be a white golf ball, yes?
kbsparky 08-11-2011 08:21 PM
All the wires (Black, Red, White) are current-carrying conductors. The green wire only serves as a grounding means, and is not part of the regular circuitry.
Clear as mud?
greenhorn1 08-11-2011 09:54 PM
kbsparky
thanks for not being rude you are a big help
dmxtothemax 08-11-2011 10:31 PM
I would guess that white is one hot,
And black is another hot,
If it is set up for 240v.
As for the grey ???
Possibbly a neutral,
But you need to double check this first.
Meter across grey and black = 120v.
Meter across grey and white = 120v.
This would indicate the truth.
But if you have any doubts,
Get an electricain,
Dont take chances with 240v
doubily dangerous.
a7ecorsair 08-12-2011 07:50 AM
I think the guys were just having some fun...
Come back and give us a better description of your project. You may have a picture in your mind of what it looks like but we can't see your project so that is why it is important to lay things out so we can see it:yes:
1) Tell us why you are doing this - is it a new range replacing an older unit?
2) Is there an existing wall receptacle and does it have three pins or four pins?
3) Is the cord already attached to the range?
