4 Wire To 3 Wire Relay - Electrical - DIY Chatroom Home Improvement Forum
Old 07-04-2012, 07:31 PM   #1
4 wire to 3 wire relay
I have an omron LY2 12vdc acting as a relay for a projector screen. I wasn't able to get the screen to move so unplugged everything from the relay (without taking note of how they were plugged in to begin with), and tried to connect the two sides of the power cord to see if that would elicit a reaction. One side of the cord however is 4 wire (connected to projector) and the other is 3 wire...I don't know what to do with the extra red wire and I don't know how to plug it all back into the relay, any ideas on the subject would be appreciated.
Thanks.
bkonk is offline   Reply With Quote
Old 07-05-2012, 04:18 AM   #2
JOATMON
ddawg16's Avatar
Rewards Points: 850
I would stop right there......
If your trying to bypass the relay....chances are, you will blow something. Relays are commonly used to operate things when you have a difference in voltage. The Omron relay has a 12Vdc coil....but it could be switching 120Vac....so, you don't want to be bypassing the relay....not unless you want a new screen and/or projector.
The Following User Says Thank You to ddawg16 For This Useful Post:
PaliBob (07-05-2012)
Tags
relay wire
4 wire to 3 wire relay bkonk Electrical 0 06-30-2012 09:37 PM
ceiling fan wicked97 Electrical 4 08-21-2011 09:12 AM
convert 3 wire range junction box to receptacle filby Electrical 0 06-05-2011 02:33 AM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 10:41 PM
Stranded wire on screw connections BigJimmy Electrical 7 01-19-2008 03:42 PM
