Old 11-09-2008, 10:04 PM   #1
4-way switches as regular
can 4-way switches for lights be used as a regular one. i found some on sale for 1$ each.
drewhart is offline   Reply With Quote
Old 11-09-2008, 10:21 PM   #2
Electrician
4-ways generally have a good snap sound to them.
chris75 is offline   Reply With Quote
Old 11-09-2008, 10:44 PM   #3
so. what does that mean? can it be used as a regular switch or not?
Old 11-09-2008, 11:33 PM   #4
DIYer
Just use diagonal lugs, and don't try to use it as a 2-pole, and it will work.
Gigs is offline   Reply With Quote
Old 11-10-2008, 08:34 AM   #5
how does a diagnal lug work?
Old 11-10-2008, 09:39 AM   #6
joed's Avatar
To answer the questoin - YES they can be used as a single pole switch.
Old 11-10-2008, 09:54 AM   #7
RippySkippy's Avatar
I hate to reply if you have to ask...but here goes......
It's the screws on opposite corners of the switch. One way it's on...the other it's off. Remember to turn off the power when mess'n with electricity...
when it comes to breakfast, the chicken is dedicated, the pig is committed.
LMASD
RippySkippy is offline   Reply With Quote
Old 11-10-2008, 05:50 PM   #8
A single pole switch is only 50 cents.....and it says on/off
But yeah, you can use them. You have a 50/50 chance of choosing the right two terminals and a 50/50 chance of installing it right side up.
220/221 is offline   Reply With Quote
Old 11-11-2008, 12:50 PM   #9
Yes it will work fine. Connect one wire to a light colored screw and the other wire to a dark colored screw. Prior to installation you will need to use a multimeter to determine which combination of screws has the light turned on (close to zero ohms between the chosen screws) when the switch handle is up.
3 switches 1 light. need 2 lights 2 switches. Im desprete s richards Electrical 6 07-19-2008 04:18 PM
50+ year old home-all light switches one-way? mudpaw Electrical 13 06-22-2008 02:57 PM
light switches wired in series -- why? magnolia Electrical 2 05-11-2008 12:16 PM
Need help replacing switches in four-way circuit magnolia Electrical 3 05-09-2008 10:40 PM
uniformity of light/power switches through house joeyboy Electrical 3 09-12-2007 10:24 AM
