4-way switches as regular
can 4-way switches for lights be used as a regular one. i found some on sale for 1$ each.
so. what does that mean? can it be used as a regular switch or not?
Just use diagonal lugs, and don't try to use it as a 2-pole, and it will work.
how does a diagnal lug work?
To answer the questoin - YES they can be used as a single pole switch.
It's the screws on opposite corners of the switch. One way it's on...the other it's off. Remember to turn off the power when mess'n with electricity... |
But yeah, you can use them. You have a 50/50 chance of choosing the right two terminals and a 50/50 chance of installing it right side up.:thumbup: |
Yes it will work fine. Connect one wire to a light colored screw and the other wire to a dark colored screw. Prior to installation you will need to use a multimeter to determine which combination of screws has the light turned on (close to zero ohms between the chosen screws) when the switch handle is up.
| All times are GMT -4. The time now is 04:38 AM. |
