4 Way Switches In New Code - Electrical - DIY Chatroom Home Improvement Forum
Old 12-29-2011, 06:27 AM   #1
Rewards Points: 89
4 Way Switches in new code
Question
Will I need to run something other than a 12/3 wire between my three way/four way/three way switch legs due to the new code requiring a common,or does the third (common) wire in the 12/3 suffice.
Thanks in advance for your replies,and I hope everyone had a good holiday.
spring3100 is offline   Reply With Quote
Old 12-29-2011, 06:47 AM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,216
To meet the NEC 2011 code you will need 4 conductors plus ground.
Coastal South Carolina
Old 12-29-2011, 06:53 AM   #3
Code05's Avatar
Rewards Points: 1,104
Wanna tell me why? Only one neutral required.
12/3 would be sufficient- 2 travelers plus a neutral.
404.2(C) Switches Controlling Lighting Loads. Where switches
control lighting loads supplied by a grounded general purpose
branch circuit, the grounded circuit conductor for the controlled
lighting circuit shall be provided at the switch location.
Code05 is offline   Reply With Quote
Old 12-29-2011, 07:21 AM   #4
Julius793's Avatar
Ye what would you do with the fourth wire?
Electricity will kill you if you give it a chance
Julius793 is offline   Reply With Quote
Old 12-29-2011, 07:26 AM   #5
Code05's Avatar
Not required, but it could be a hot for a receptacle or such later.
The Following User Says Thank You to Code05 For This Useful Post:
gregzoll (12-29-2011)
Old 12-29-2011, 07:34 AM   #6
Julius793's Avatar
Well of course I can run 12-3 or 12-4 all over my house just to have extra wires, my point was he said code requires it! Now code doesn't require it so youll have it just in case!!
Old 12-29-2011, 08:17 AM   #7
Rewards Points: 758
It could be 12/3 or 12/4, depends on how it's wired. You may not always have 2 travelers and a neutral with 12/3.
You need a neutral in the box in case you ever put in a switch that requires a neutral. That's why the code change.
Check with your AHJ to be sure. Fortunately MA has an exemption on this part of the code.
AandPDan is offline   Reply With Quote
Old 12-29-2011, 12:44 PM   #8
A "Handy Husband"
rjniles's Avatar
3 wires gives you 2 travelers plus the wire that will connect to the common at the far end, not a neutral. That 3rd wire can be a constant hot or the switched hot to the fixture. 4th wire will give you a neutral at the 4 way and the far end 3 way.
Old 12-29-2011, 08:14 PM   #9
Licensed electrician
Rewards Points: 1,634
This would depend on the wiring scheme. A xx-3 cable can supply the two travelers and a neutral.
The wire off the common can come off the last switch.
Old 12-29-2011, 08:28 PM   #10
Easy solution
All you need is 3 wire plus your ground.
here is an easy diagram to follow.
http://www.wfu.edu/~matthews/courses...ariations.html
Frank67 is offline   Reply With Quote
Old 12-29-2011, 09:03 PM   #11
MarginallyQualified
Rewards Points: 2,464
Does the OP live in an area that has adopted this code change?
Old 12-30-2011, 05:58 AM   #12
A "Handy Husband"
rjniles's Avatar
Jim,
Rethinking, I realize my answer was based on the power feed and the fixture wired from one of the switches. If the power is at one switch and the fixture is at the other end, 3 wires is enough.
Old 12-30-2011, 06:10 AM   #13
Julius793's Avatar
Jim,
Now that makes I little more sense
Old 12-30-2011, 08:01 AM   #14
Jim,
I knew you knew this but wanted to clarify that some wiring schemes you could be sorrect but that with others a xx-3 was sufficient.
added new switches, one of 2 old switches doesn't work anymore MLMIB Electrical 6 06-13-2011 09:10 AM
Changed switches, now no power to switch OrchardHouse Electrical 8 05-28-2011 07:16 AM
Bryant +80 furnace code 32 shalenkur HVAC 0 02-18-2011 09:38 PM
error code 45 Turtle learner HVAC 2 01-10-2011 04:09 PM
Distance between Heater & Combustibles DIY_JC Building & Construction 7 01-20-2009 07:52 AM
